JAY X
Fader + trafo buffer
« on: November 21, 2019, 11:50:18 AM »
Hi!
Attached is a schematic of a fader amplifier with an inductor (L32)  in paralell to the output resistor.(R145).
I thought that instead of using another opamp as buffer for the output transformer,(Sowter 8403X), i could combine both circuits within the fader amplifier. But i'm not sure...This is why i ask here... :D
Thank you for your help!
Jay x
Re: Fader + trafo buffer
« Reply #1 on: November 21, 2019, 12:28:32 PM »
It is not clear to me what is wrong with the circuit as it stands. Is it the inductor that bothers you. It is only 3.9 microhenries so it is very small. It is necessary for op amp stability.
JAY X
« Reply #2 on: November 21, 2019, 01:37:52 PM »
Hi Ian!,
So, the circuit is correct.
I just wanted to make sure it is ok. :)
Jay x
« Reply #3 on: November 21, 2019, 03:13:51 PM »
Hi Ian!,
Jay x
Yes, it is correct. The series resistor with a parallel inductor is common in transformer drivers.
JAY X
« Reply #4 on: November 25, 2019, 05:55:06 AM »
Hi!
In case i change the type/brand of output transformer (carnhill CA 18 2407, or VTB 2407), with  the same circuit, i have to change the inductor value acordingly..┬┐right?
Another different story would be to drive output transformers with a class A circuit like the BA283AM...in that case i don't need the inductor, but follow the fader amplifier with the BA283 output stage... 8)
Jay x
« Reply #5 on: November 25, 2019, 12:45:42 PM »
Hi!
Pass. I am not familiar enough with that design to be able to answer sensibly.
Jay x
The BA 283 would replace the fader amplifier.
JAY X
« Reply #6 on: November 26, 2019, 03:49:21 AM »
Hi Ian!
Ok, Great!!
Jay x
« Last Edit: November 26, 2019, 08:23:38 AM by JAY X »
JAY X
« Reply #7 on: November 28, 2019, 05:27:10 AM »
Hi!
After reading more about Neve circuitry, I see that some parts run at 24v and others at +/-12v. (BA512 opamps).
Running these circuits at higher voltages, ( +/-15v or +/- 18v) would require change some bias resistors.
But as many audio opamps like NE5532 can work at +/- 12v, it is no problem combining these stages together, except for voltage swing.
Jay x
« Reply #8 on: November 28, 2019, 12:38:31 PM »
When I was at Neve back in the mid 70s, everything ran on 24V. Audio circuits, relays and lamps all from one 24V power supply. While I was there, the R&D department carried out a range of tests on a brand new op amp that had just been released by Philips. It was not called the NE5534 at that time. Instead it had a TDA number (I cannot rememeber the number) but it later became the NE5534 and NE5532. They were not introduced into Neve products until after I left  so I do not know to what degree the two types of circuit lived alongside each other.
abbey road d enfer
« Reply #9 on: December 06, 2019, 01:36:13 PM »
It is correct in the sense that it will make some sound, but you don't need the inductor, the 330pF cap is largely enough to ensure stability.
I guess this LR network was intende to decouple capacitive loads, which is not necessary anymore since you have a xfmr.
I would ditch the inductor and the 47r, increase the output cap, since it sees very small offset voltage, you could use a 6V rated cap and increase it to 1000uF.
I would also implement two paths for negative feedback, one as it is but increasing R146 to 10k and adding a 10k from the other side of C74; that would be in order to tame the VLF hump due to the resonance of the output cap with the primary of the xfmr.
« Reply #10 on: December 07, 2019, 06:26:40 AM »
All good suggestions and advice.
If you want to sound crazy please tell me about THE DEEP STATE.
JAY X
« Reply #11 on: December 09, 2019, 10:39:23 AM »
Hi!
Ok, i will try to post a new schematic with these suggestions!
Jay x
Last post September 15, 2004, 07:12:28 AM
by Svart
Last post March 13, 2008, 08:34:51 PM
by clintrubber
Last post December 08, 2006, 06:07:25 PM
by shabtek
Last post December 31, 2008, 01:25:04 PM
by porkyc
