johnheath Well-known member Joined Jul 31, 2014 Messages 890 Location Sweden Nov 27, 2019 #1 Hi all... I have a question regarding what happens if the maximum voltage between heater and cathode is exceeded? I just want to get my head around this even if it is a noobie question Best regards // John
ruffrecords Well-known member Joined Nov 10, 2006 Messages 16,263 Location Norfolk - UK Nov 27, 2019 #2 The insulation between the two may break down. This will increase leakage between heaters and cathode. At a minimum it will induce hum into the cathode, at worst it could lead to a heater cathode short. Cheers Ian
johnheath Well-known member Joined Jul 31, 2014 Messages 890 Location Sweden Nov 27, 2019 #3 Thank you Ian A short and solid answer as usual. Best regards // John
gyraf Well-known member Staff member GDIY Supporter Moderator Joined Jun 4, 2004 Messages 11,884 Location Aarhus, Denmark Nov 27, 2019 #4 ..plus (in my experience) you tend to get tubes dying too early of microphonics if you run them too hard in this regard..
johnheath Well-known member Joined Jul 31, 2014 Messages 890 Location Sweden Nov 27, 2019 #5 Thank you Gyraf I have heard about this before but no one has been able to confirm it. I guess that avoiding a voltage too close to the limit is highly recommended best regards // John
