pmercer
Altec 9470A build
« on: December 05, 2019, 10:16:18 AM »
I have the set of 6 in trays with the power supply. Goal is to wire up 6 JLM Go Betweens, 150/600 switches on the inputs, and the Bourns 600 T pads on the outs. Question is, I want to take a tap off the +24VDC from the built in power supply, bring it up to 48 for the phantom on the Go Betweens...how would I do this? Manual says the supply can support 15 pres and puts out 2A, each module shouldn't exceed 130ma so I'm only at 780ma with the pres themselves.
http://www.studiomanuals.com/docs/altec/Altec-9470A-MicPre.pdf
Re: Altec 9470A build
« Reply #1 on: December 05, 2019, 11:04:41 AM »
Add one of the small Meanwell 48V enclosed switchers to the back of the rack.  I've written about them elsewhere here.
pmercer
« Reply #2 on: December 05, 2019, 11:53:46 AM »
Thanks Doug...any specific model you recommend? I want to come straight off the +24vdc...
« Last Edit: December 05, 2019, 02:29:05 PM by pmercer »
« Reply #3 on: December 05, 2019, 03:18:54 PM »
no, separate supply from the wall AC.
Last post May 26, 2007, 02:16:10 AM
by Silvas
Last post October 12, 2007, 12:12:26 PM
by EmRR
Last post January 27, 2020, 02:14:42 PM
by Whoops
Last post November 18, 2012, 01:41:23 PM
by mjrippe
