I have the set of 6 in trays with the power supply. Goal is to wire up 6 JLM Go Betweens, 150/600 switches on the inputs, and the Bourns 600 T pads on the outs. Question is, I want to take a tap off the +24VDC from the built in power supply, bring it up to 48 for the phantom on the Go Betweens...how would I do this? Manual says the supply can support 15 pres and puts out 2A, each module shouldn't exceed 130ma so I'm only at 780ma with the pres themselves.
http://www.studiomanuals.com/docs/altec/Altec-9470A-MicPre.pdf
