Some guesses
Uses a relay to switch inside the microphone
SP relay changes cathode resistor value adding in parallel.
DP relay changes cathode resistor value adding in parallel and/or changes the tube plate voltage by adding a resistance in series "above" the plate resistor.
The VMA PS mounted switch could also adjust B+ voltage and heater voltage supplied to the microphone.
I am curious what is being done.
