Gus
something different
« on: December 14, 2019, 05:17:37 PM »
I bought a tube microphone for experimenting with solid state tube replacement. It has a good size body and removable tube.
So I traced it and found something different the rest of the circuit is standard stuff
I checked my trace a few times
The part identifiers in the sim don't match the PCB markings
I made up the capsule value because I have not measured it yet.
has anyone seen a circuit fragment like this before?
RuudNL
Re: something different
« Reply #1 on: December 15, 2019, 04:35:34 AM »
Normally, I would expect R7, C7, C8 and R8 to be a single capacitor.
The same goes for R3, C3, C4 and R4.
I can't think of a reason why they used these extra components.
Would be interested in your opinion!
There is a solution for every problem!
http://www.vansteenisaudio.nl
Gus
« Reply #2 on: December 15, 2019, 09:37:45 AM »
I posted this because I am puzzled by what I traced
The .001uf caps are 400V
I will trace it again.
abbey road d enfer
« Reply #3 on: December 15, 2019, 12:09:03 PM »
It looks suspiciously like the circuit in some Neumann mics for injection of a test signal.
RuudNL
« Reply #4 on: December 15, 2019, 03:12:15 PM »
If that was the idea behind it, they could have omitted R4/C4 IMHO.
A signal injected over R8 (almost) wouldn't reach the grid.
« Last Edit: December 16, 2019, 05:21:13 AM by RuudNL »
moamps
« Reply #5 on: December 15, 2019, 06:08:42 PM »
IMHO, the network R7, R8, C7, C8 does not have any purpose (it's separated with 1Gohm from the capsule).
The upper network may be a HF boost (or not, it needs to be further analyzed).
Gus
« Reply #6 on: December 15, 2019, 07:35:50 PM »
I wonder if it is to mislead others or to check if someone copies this circuit.
The power supply has a HPF inside and invert switch.
The fil supply 7806 has its tab connected to PCB ground however, it has a diode in the middle ground lead to ground. So the diode is shorted out. I checked with a meter
This can be a good thing because the voltage is closer to 6VDC and not 6.6VDC(with the diode)
The high resistance parts in the microphone are PCB mounted.
I don't see an AC modulation from the capsule or gain stage(EF86 as a triode) via the parts.
« Last Edit: December 16, 2019, 05:01:01 AM by Gus »
RuudNL
« Reply #7 on: December 16, 2019, 06:36:24 AM »
Why would they have selected such a high value for the grid leak resistor?
With 60 pF (capsule), a 100 M.ohm grid leak resistor would result in a -3 dB point at 26,5 Hz.
Phase shift at low frequencies is the only reason I can think of.
In general, you don't want the electronics of a microphone to be 'flat' to (almost) DC...
As my old electronics teacher (a wise man!)  used to say: "never select the grid leak resistor higher than needed, because it will reduce the lifetime of the tube".
abbey road d enfer
« Reply #8 on: December 16, 2019, 06:41:00 AM »
But sure you know that moving the -3 dB roll-off also moves the noise spectrum towards subsonics, don't you?
RuudNL
« Reply #9 on: December 16, 2019, 09:47:38 AM »
Yes, but it makes the microphone also more susceptible to high humidty.
Older tube microphones never used resistors in the G.ohm range (probably because they were not available at the time) but nobody complained about noise.
I have yet to see a tube microphone that has a lower self noise than a solid state microphone!
« Last Edit: December 16, 2019, 01:09:11 PM by RuudNL »
abbey road d enfer
« Reply #10 on: December 16, 2019, 12:04:27 PM »
Older tube microphones never used resistors in the G.ohm range (probably because they were not availabel at the time) but nobody complained about noise.
I have yet to see a tube micropphone that has a lower self noise than a solid state microphone!
I would think the main reason is that tubes have too much grid current for operation with gigaohm grid leak, even when run at low anode voltage and reduced heater voltage, resulting in too high negative bias and tube cutoff.
Gus
« Reply #11 on: May 24, 2020, 01:40:54 PM »
Anyone have  a chance to look at the microphone model and check the circuit fragment?
EDIT
I need to check it again
I would have done a different HPF.
Also the part numbers in the sim screenshot don't match the markings on the PCBs.
« Last Edit: November 06, 2020, 11:44:07 AM by Gus »
Gus
« Reply #12 on: October 31, 2020, 05:02:08 PM »
Anyone look at the current version of this microphone to check if anything changed?
bockaudio
« Reply #13 on: November 09, 2020, 10:11:33 PM »
Classic 797 filament. Could be someone copied them.
Gus
« Reply #14 on: December 17, 2020, 01:15:37 PM »
Tested it again. I often put microphones away for some time before testing them again
I removed the HPF in the power supply. The HPF did not sound good to me and removing it also removes the loading it causes even when switched off. Left the fil supply alone for now.
Stock it sounds like the two recordinghacks VO tests you can find it in. I hear the same thing in the VO tests that I hear testing it.
Next I am going to do something about the capsule grill maybe machine a new capsule mount to get rid of some of the grill frame reflections. I will also add a magic eraser foam ring.
After that change the capsule
Then make and add a circuit for using modern tubes or build a solid state to transformer, tube microphone voltage circuit to install in it.
Gus
« Reply #15 on: December 26, 2020, 12:54:17 PM »
Added a magic eraser foam ring, this made a difference.
Machining a new capsule mount for the next test
So far
cleaned the PCBs
Changed one cap
Added a cap
removed the wiring to the HPF
Added the magic eraser foam
Next
change the capsule mount
change the tube
Adjust the circuit design
change the capsule last
So far disconnecting the HPF and adding the foam made the most difference
Last post November 14, 2009, 02:26:10 PM
by dmlandrum
Last post November 15, 2009, 12:38:47 PM
by dmlandrum
Last post July 12, 2010, 03:28:20 PM
by PRR
Last post September 10, 2013, 05:30:08 AM
by warpie
