trobbins said:parallel : parallel
+1to what CJ says.dogears said:If you’re going to wire a quadrifilar transformer in 1:1, is it best practice to do it parallel : parallel or series : series?
dogears said:As for leaving them floating - I've found that can do odd things to transient response. Folks at Jensen recommended loading the unused winding (if 1:2) with a 10k or something rather than leave it dangling.
Parallel the pris. Minimizing DCr of the resultant pri reduces THD and improves LF response.john12ax7 said:I've wondered what is optimum for 1:2. Is it preferable to leave a winding unused (terminated), or would it be better to parallel the primaries?
abbey road d enfer said:Parallel the pris. Minimizing DCr of the resultant pri reduces THD and improves LF response.
I spent some time experimenting and simulating xfmrs, using detailed models that included multiple stray capacitance. The best case is a balanced source and a balanced receiver. When leakage inductance and stray capacitance start to roll-off, capacitive coupling between windings takeover and extend HF response way beyond the AP's limits.CJ said:Now, what if we wire it in series and run it out of phase that is, have the polarity of the signal flipped as it passes thru the xfmr? Now you have AC voltage gradients scattered throughout the coil such that the difference in potential along the length of the parallel wires will contribute to who knows what!
abbey road d enfer said:Worst case is when the primary is grounded on one side and the secondary drives a receiver that's grounded on the other side; then capacitive coupling is out-of-phase with magnetic coupling, resulting in significant HF roll-off.
You're absolutely correct. They also have a magnetic shielded enclosure, which IMO is even more important than electrostatic shielding. However I just tried it, put that in a box and ended up selling 1000's of them... people just learned not to put them close to guitar amps, keyboards and equipment racks.Winston O'Boogie said:I will say that I've never seen an example of a quadfilar transformer being used as a 150 ohm mic splitter as you did with your own custom transformers. Generally, these are seen with an electrostatic shield between the windings but, hey, if it works
There are a couple of threads here about this. PRR, whom I respect a lot, was of the opinion that the best spec is describing a preferred usage. That is one of the few points where we may disagree somewhat. Anyway, the level of variability of primary characteristics, particularly inductance implies lengthy specs that many potential buyers would be deterred by.*** Edit: on the whole, manufacturer's data is mostly thin on the ground in my opinion. Of the bigger known names, Carnhill, followed by Sowter seem to be the worse in that regard.
abbey road d enfer said:They also have a magnetic shielded enclosure, which IMO is even more important than electrostatic shielding.
abbey road d enfer said:There are a couple of threads here about this. PRR, whom I respect a lot, was of the opinion that the best spec is describing a preferred usage. That is one of the few points where we may disagree somewhat. Anyway, the level of variability of primary characteristics, particularly inductance implies lengthy specs that many potential buyers would be deterred by.
It could have been a possibility, but it was not a market I was addressing.Winston O'Boogie said:Indeed, that would be absolutely vital here. I'd just assumed and was envisioning yours as being potted in a large shielding can, but if an enclosure worked and you sold 1000's , then your design was good and that's that. Nice one. I suppose mid/side encode/decode would have been another use for these units.
That's right, but you can have a nice conversation with Brian S, and then you will know much more. You have to convince him you know what you're talking about.A Sowter can cost that much and sometimes not even have a data sheet of any sort.
abbey road d enfer said:Worst case is when the primary is grounded on one side and the secondary drives a receiver that's grounded on the other side; then capacitive coupling is out-of-phase with magnetic coupling, resulting in significant HF roll-off. Simulating with lumped elements results in severe notches in the response.
No. Adding a resistor in the drive path is detrimental to THD and frequency response.Rob Flinn said:Is there any case where driving to ground through a resistor would improve this scenario ? Rather like the quasi balanced outputs one gets nowadays.
Indeed: too much negative impedance turns the circuit into an oscillator.Winston O'Boogie said:Here's the Lundahl pdf showing the basic idea of sensing the current to create this "almost" inverse of the primary dcr. In practice, the sense R is best adjusted in situ for lowest THD but, If in doubt, err on the low side.
