Munro egg 150 L R mismatch
ilfungo
ITALY
From 2 weeks,
the right monitor sound 2-3 db less then the left,
my sensation is also different in frequency response... I have tryed to contact Se electronics but without luck...
Someone had the same problem before?
Could be an amp problem? Suggestions?
THANKS!!!
Can you swap the leads to the speakers. If the level drop goes with the switch it is an amp problem, if it stays with the speaker then the speaker itself is at fault.
Thanks bremusound!
On Ian's advice I swapped the outputs from the amplifier but nothing changes ...
so it's not an amplifier problem ...
I will check the cables and connectors...
ilfungo said:
Thanks bremusound!
I had one other thought. Now you know it s not the amplifier because you switched the speaker leads. But it might be the amp input stage. To check this you need to swap the leads on the amp input. If it stays the same it is definitely the speakers. If it swaps when you swap it is either your source or the amp input.
ian
I have already inverted the inputs and the problem is always on the same monitor.
Thanks Ian!
