Anyone know a source of push button caps that fit the Alps SPPH4 series of push buttons. I think the opening needs be about 3.3mm square.
Rocinante said:
I bought some SPPH4 push buttons and some caps. The caps fitted OK but I did not use the switches in the end because they are too tall. If the plunger had been 3mm or so shorter they would have been fine.Elmicha said:Hi ruffrecords,
finally, did you use the round caps together with the SPPH4 series? Did they fit well?
Thank you!
Greets,
Elmicha
