Neve connector (1272 back panel)
peterc
Johannesburg, South Africa
Hi all
Anyone know where to find the 18 way back panel connector for the 1272? I'm doing some work on a number of these & I'd like to find a proper connector instead of etching PCB's to fit in there as I have done in the past!
It is an 18way male connector with a 0.15" pitch on the terminals.
Many thanks
Peter
Hi Peter,
It's Digikey Part # EDC306180-ND 18-pin Edac edge card connector. Edac's part no. is: 306-018-500-102
:sam: :guinness:
Hi JR
Thanks for the reply, but is that not the Female EDAC?
(pic here : http://rocky.digikey.com/WebLib/EDAC/Web%20Photo/306-018-500-102.jpg )
What I need is the Male part that plugs into this.
Regards
Peter
Hi Peter,
I don't actually know if there is a male connector - I've only ever seen the male end as traces on a PCB or an extender card or the like. It will be interesting to find out.
:thumb:
This one?
Amphenol part 133-018-21
peter-
the original connector was made by amphenol, dont knwo if that helps you or not. Ebay is probably your best bet for something like that.
dave
There are a couple of N*eve spare parts auctions up on ebay.com right now. There are also a couple of sites that sell the part you seek. Check these:
http://www.phoenixaudio.net/spare.htm
http://www.danalexanderaudio.com/parts.html
http://www.shep.co.uk/servic.htm
There are more
I also don't know the part # for the male half, only the female. If anyone is still making it, these parts numbers should help you track it down:
Amphenol 133-018-21
Wire Pro Industries 143-018-01 (aka WPI - currently in production and found at Newark/Farnell as well as Allied, IIRC)
[EDIT] jrmintz - That's a nice find! :wink: Mouser has it for $2.76. That's $10 less than the WPI version (all gold contacts).
