mic pre output biasing
dogears
Texas
A friend sent me this snippet, I believe its from an old Midas desk. Simple enough op amp arrangement, but I'm not sure I understand the purpose of the 12k resistors to +V?
Is it creating a higher output bias voltage since the desk is single supply?
There are two 12k resistors to +v....
One creates a +V bias across the output electrolytic caps, the other creates a modest +V bias across the capacitor in the gain leg..you can figure out which is which.
I presume they expect that to make the (polar) electrolytic caps behave better..
Not trying to be dense, but in that case why not just omit the first capacitor altogether?
And -- happy new year, and thank you for your patience with my basic questions.
This is pretty basic stuff....  but I'll play along for now. Perhaps find a book on basic electronics to read.
Capacitors block DC but pass AC (a simplification).  Capacitors in series with the output of a circuit, prevents DC from corrupting the audio output.
Polar electrolytic capacitors have a preferred orientation wrt the DC they are blocking. The fat plate in the schematic representation indicates the positive end.
Putting two polar caps in series with both + leads connected together and that junction biased up to a DC voltage that is positive wrt the output insures the caps are seeing proper voltage across each while blocking DC from the audio output.
Sorry I'm asking unclear questions. Yes, I have that much square.
Looking at the datasheet for the TDA1034N we actually get the input offset voltage and bias current. Vio max 4 mV, input bias current max 1.5 uA.
For this, in the two gain positions you get worse case offset ranging from -2  to  +46 mV. Typical would be -1 to +6 mV.
So why not just use the single tantalum, oriented just the way it is, and flip  C3?  Is a 1.5V bias really going to matter?
Two electrolytics back-to-back with / without a bias voltage applied is supposed to reduce distortion with cheap electrolytic capacitors. Yes, you could just replace both with one tant. I think that's why it shows the tant option there. But today even the cheap electrolytics do not need this sort of jury-rigging. So this circuit is not really worth exploring for it's design. If you're trying to decide how to recap and with what, that is a different discussion.
Also this does not look like it's single-supply. Otherwise C3 would be reverse biased and the input transformer would require a cap.
Yeah, I just didn't get it. If I were recap I'd at least start by removing the biasing and leaving the tantalum. Or measuring the offset voltage to begin with.
Ah you're right. they're just pulling from +V for the cap biasing.
