Sunrise buffer box
« on: January 01, 2020, 11:21:41 AM »
Hey there,
Im aware that we are not allowed to post schematics of this.... still in production. Still, does anyone have info on whats inside? What opamp they use? Id love to build one in my yamaha thr10. would be much nicer that carrying a seperate box
midwayfair
Re: Sunrise buffer box
« Reply #1 on: January 01, 2020, 02:32:12 PM »
The one I fixed was a Burr Brown FET op amps. I don't remember exactly which one, but it really shouldn't matter that much.
There's really not much to the circuit. It's pretty much a datasheet audio circuit in a steel box.
... Also, it was perfboard wrapped in black electrical tape. Maybe that adds some mojo.  ::)
I'm Jon. Myself's music and things I make: jonpattonmusic.com. My band: www.midwayfair.org. [Disclaimer: PCBs of guitar pedals I've designed are sold by Madbean, 1776 Effects, and JMK PCBs.]
« Reply #2 on: January 01, 2020, 03:52:42 PM »
Do you think a simple fet buffer like this will do the same? They dont spec input impedance but when building the fet version i guess it should be 1Meg  or up?
https://www.musikding.de/docs/musikding/buffer/bufferschalt.pdf
abbey road d enfer
« Reply #3 on: January 01, 2020, 04:31:09 PM »
What brand of tape? That's where the magic is...  ;)
« Reply #4 on: January 01, 2020, 06:59:02 PM »
unwrapped a  brand new buffer box,
the IC has the designation sanded off,  it is a single op-amp.
there was no electrical tape.  the board was encapsulated in yellow shrink wrap.
if you want to know the details,  contact Dave Collins, he designed it for Mr. Kaufman.
abbey road d enfer
« Reply #5 on: January 02, 2020, 01:06:30 AM »
Actually it's about 400k. I think it would be correct for most passive p/u's, even piezo types.
I know some go crazy about high impedance for piezo's, like 10 Meg or so, but I always find it too boomy and need to low-cut.
I found that between 500k and 1Meg works good most of the times.
« Reply #6 on: January 02, 2020, 01:31:09 AM »
1M2 is my "go to" but yes, 500K sounds better on some pick-ups.   A tweaker's box would allow the load to be altered to suit I guess.
abbey road d enfer
« Reply #7 on: January 02, 2020, 01:56:46 AM »
Several possible candidates, however the claimed current draw (0.15mA) limits the number of potential suspects. And it looks like none of them is particularly low-noise.
Aah! but it changes everything; shrink tube, particularly the yellow one, has a very different sound.  :)
« Reply #8 on: January 02, 2020, 06:06:55 AM »
Thanks guys,
Do you think i could bump up the impedance to 1meg on the kit i have posted somehow? Or does anyone have a different schematic? I do think i should aim for a 1meg input resistance.  Thanks a lot
Will this one be higher:
http://www.generalguitargadgets.com/pdf/ggg_buffer_jfet_sc.pdf
« Last Edit: January 02, 2020, 06:16:18 AM by salomonander »
abbey road d enfer
« Reply #9 on: January 02, 2020, 09:39:45 AM »
Thanks guys,
Make R1 & R2 2.2Meg and R5 4.7Meg.
Yes, that one is 1Meg, but note it is a source-follower so it is unity gain.
squarewave
« Reply #10 on: January 02, 2020, 11:30:08 AM »
If a 3 pole switch is used, why not use the 3rd pole to deliver power? Then you don't have to unplug it to save battery. With an extra high Z input and careful pop control you could do the same with 2 poles.
Although I don't understand why someone would bother with a one transistor circuit like this. It's a little too simple. No drive. An op amp is worth the extra few mA. NJM4556 works is battery friendly and has excellent drive (same op amp used in the O2 headphone amp).
abbey road d enfer
« Reply #11 on: January 02, 2020, 11:45:13 AM »
OP wants to install it in his Yamaha THR10, so I suspect he would power it post power switch.
Being bipolar, NJM4556 is bound to have high input noise current, which is incompatible with high-Z sources. Its operating current of 9mA typ., which is not an issue in this particular case, can be a no-go for battery powered applications. There are several JFET opamps with a comparable input noise voltage and much lower noise current and much smaller operating current.
PRR
« Reply #12 on: January 02, 2020, 12:02:43 PM »
Why does a Yamaha THR10 need some "buffer box"?
abbey road d enfer
« Reply #13 on: January 02, 2020, 12:15:30 PM »
Probably for the same reason he carries a separate box...  ???
« Reply #14 on: January 02, 2020, 12:44:41 PM »
Thanks a lot guys. I will try upping the resistors as suggested. Ill let you know.
Whoops
« Reply #15 on: February 04, 2020, 11:01:17 PM »
Take a look also here, it's a very nice article on guitar buffers:
http://www.muzique.com/lab/buffers.htm
« Reply #16 on: March 06, 2020, 12:51:34 PM »
Hey mate,
Are you certain about the math here? I just built this and get a big level drop with the resistors you recommended.
abbey road d enfer
« Reply #17 on: March 06, 2020, 07:26:11 PM »
Hey mate,
Is it the FET or the Si NPN version?
The SiNPN version would not work well but the FET should. What type of capacitor have you for C1? Electrolytic would be too leaky. You don't need 1uF with the FET, 0.1uF is largely enough. Note that this buffer is a voltage-follower with 0dB gain.
« Last Edit: March 07, 2020, 02:57:44 AM by abbey road d enfer »
« Reply #18 on: March 07, 2020, 05:34:30 AM »
Thanks mate, maybe i did some error.... but built this twice with the same result. And yes, the fet version. Ill try around more im certain its my fault somehow. Just wanted to double check the values. Thanks for your quick reply! Oh and i use wimas with the correct values.
Maybe i need another circuit after all... even if this was working.  My yamaha does not power the sunrise pickup really. Its way too quiet
« Last Edit: March 07, 2020, 05:37:33 AM by salomonander »
abbey road d enfer
« Reply #19 on: March 07, 2020, 12:40:08 PM »
Did you really experiment more gain with the original values?
Last post September 15, 2004, 07:12:28 AM
by Svart
Last post October 06, 2005, 01:01:08 PM
by peranders
Last post June 02, 2007, 01:46:23 PM
by deveng
Last post May 11, 2013, 11:46:13 PM
by niklasni1
