Schematic request: SPL Kultube
iampoor1
California
Anyone uaveba schematic for this?
I have one on the bench that will not engage the bypass relays. The "active" switch blinks. All the other relay activated circuits work fine.  I don't have a problem tracing it out...but a schematic would certainly be nice.  ;D
pucho812 said:
what is the power supply doing?
seems to me that would be the first place to inspect for issue?
Power supply is okay. Solid +12.5v on the test point for the relays.
I'm closer inspection, it looks like I have some broken traces and some very questionableable pads. Someone else has been in the unit before me and put jumpers over the bypass relays.  :(
to quote inspector clouseau "Ah yes, I see"
Hello, My Kultube has started doing the same thing...Active light just flashes and does not engage. Did you find a solution to your one? Also do you have a schematic?
Neill.
Neill.
I have the same issue with my Kultube. Have you been able to solve it? I tried swapping the tubes, with no success.
