xeawr
Re: DESPERATION! No heater voltage on Stellar/Alctron tube mic power supply
« Reply #80 on: February 04, 2020, 06:02:47 AM »
Here you can hear and see the differences between the two power supplies.
(ca. 40-50dB preamp gain + 40dB boost in DAW - don't mind my wall clock in the background)
TBONE PSU NOISE:
AUDIO (online player - link corrected)
https://voca.ro/jcyyuAPg8Id
ALCTRON PSU NOISE:
https://voca.ro/jBvB2AHnlkb
« Last Edit: February 04, 2020, 10:23:34 AM by xeawr »
moamps
« Reply #81 on: February 07, 2020, 05:37:06 PM »
I found two old original PCBs from power supply of stock Alctron HT-11A (https://groupdiy.com/index.php?topic=51377.0) during a cleaning some bins today.
R15 is 2 Ohms in original design, not 20 ohms which is obvious error in a schematics floating around. Just for reference.
xeawr
« Reply #82 on: February 13, 2020, 08:33:21 PM »
Awesome, good to know! Thanks so much!!!
xeawr
« Reply #83 on: February 29, 2020, 11:06:43 AM »
Pleeeeease, I still need your help!!!
I still have hum inspite of:
- removed the LM317 circuit, replaced  with a 7805+diode
- replaced most capacitors on the B+ side with real Nichicon ones (left only 2 original caps).
- tightly twisted the tranny secondaries
- made sure all DC components are as far as possible from the high voltage AC lines and the tranny
- reflowed the remaining solder joints, cleaned the pub
it all works but I still get hum!!!!
>> turning PS off: hum instantly disappears
>> switching just the 6.5v heater off: hum remains
It drives me nuts, I mean it's a power supply. How can these things give u so much of a headache????
Please please help me with this, I really want to find and fix the problem.
Thank you so much!!!
Khron
I don't suppose the power supply has a ground-lift switch for the XLR output, does it?
I'm thinking there's a possibility of a ground-loop occurring between the mic supply and your preamp / mixer / interface.
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
xeawr
Thanks Thron! Actually I had the same idea yesterday as I went to bed. I'm soldering a "ground-lift" cable now, see if that helps. Will keep you posted!
THANKS SO MUCH SO FAR!!!!
xeawr
Unfortunately it doesn't make any difference with the ground lift.  :( . Does it help knowing that the hum is not there when I power it off? (instantly cuts off)
Any hints where I could be looking for the culprit?
Khron
Where and how did you connect that?
xeawr
I took an XLR cable and removed ground from the male side of the XLR (neither pin1 nor the metal loop was connected)
RuudNL
Just build a new power supply. Much quicker!
There is a solution for every problem!
http://www.vansteenisaudio.nl
Last post December 22, 2007, 01:56:11 PM
by tony666
Last post October 28, 2009, 03:37:30 PM
by riggler
Last post May 19, 2012, 06:43:54 PM
by ibvee
Last post January 15, 2013, 09:52:24 AM
by dmp
