Multicard Audio Device Layout
r2d2
A-rea 51
Hi to all ,
a thread to talk about how to avoid ground , gnd , and other troubles ,
setting up  a multi card audio device ,
in attached an image about as example ,
any opinion , help , etc… are welcome ,
please say yours…
thanks and cheers
Seems un-attached when I try to view it.
hello "PRR"
re attached
let me know if you see it ,
cheers
ps:
it is so curious …
immediately after attached is posted ,
it is visible for some time
and  after for misterious reasons it disappear …
jpg - 280k
r2d2 said:
Hi to all ,
please say yours…
thanks and cheers
If inputs of said cards are differential, you should be good. Any common-mode disturbance should be eliminated.
thank for post "Abbey" !
not for all ,
but for various devices this way of multicard  in case of issues ( i .m.h.o.)  is better for repairs ,
fast card replacement  with spare cards ,
replacing damaged cards  allow to use  the device ,
while damaged card are fixed ,
in both of cases ,  live and studio situations ,
more tech opinions , helps etc.. are welcome .
cheers
not for all ,
cheers
For unbalanced interconnects, it takes a serious analysis of current circulations. All I can say is that star ground is far from being a panacea, because it allows different "grounds" to float and develop differential voltages, that are superimposed to the signal.
Hierarchical ground is de rigueur but it's often difficult to implement in a design that has multiple inputs and outputs.
After about 40 years, you get a feeling about it... :eek:
@ Abbey...
for use less cables as possible ,
cards bridges connections can be also made with m & f connectors like molex , amp etc… ,
making the psu : V+ ,  V- / 0V  ,  and gnd , enter on card n° 1 (left )
than on card 2 ,3,4 with  "cascade" bridges ,
as for the audio path  (obviously no out  for avoid loop .. ) ,
can give some  improvement ?
cheers
I have been pretty much writing about this here for years.
Inside a common chassis there is vanishingly little benefit from balanced interfaces and cost associated with additional circuitry (while impedance balanced can be done inexpensively with just an extra resistor.)
The secret sauce, as Abby already mentioned is using differential circuits. On the input side differential circuits subtract the cold (audio 0V) from the hot to extract accurate signals. Differential circuitry can also be used at outputs to reference the signal being output to a particular output ground. This is handy inside consoles to reference an audio send to the chassis ground the output jack may be bonded to.
For differential interfaces you generally need two wires, one obviously for signal, and the second for the less obvious 0V reference.  Inside a grounded chassis an additional shield is often unnecessary.
These differentials can often be incorporated into existing gain stages... for example post fader gain stages will often treat the signal going to and returning from a physical fader differentially.
This is a simplified view from 2,000 feet, but it is kind of simple when you grasp the power of differentials.
> balanced interfaces  .....  differential circuits
I whacked on a band-mixer, several PCBs, which was littered with the attached circuit. It derives the difference between source and destination "grounds" and allows for that in the signal path. Frequently the opamp had other function. I never heard "ground haze" in that board, though I never gave it a heavy workout.
@ Prr
the gnd on image refer 0V  or  negative voltages (-15 V, -18V  …) or a multi gnd line for audio and psu ?
cheers
