I am not sure why, but these are more than two sides of the same coin. If you turn a PN junction upside down it does not alternate but becomes reverse biased. One is doped with excess holes, the other excess electrons (you can look up which if it matters.)CJ said:anybody know w hy the PNP compliments always measure higher hfe than NPN?
Yup.. I suspect when complements are set up they normalize for some other factor and the beta lands where it does.we see this on a regular basis
I suspect this just is the state of solid state... or in other words I do not know the answer to your question.using 500 ma I-c and 4 V-dc to test, maybe we need to use a higher current?
thanks!
CJ said:using 500 ma I-c and 4 V-dc to test, maybe we need to use a higher current?
