this is my first post here.
I usually build custom gear and last year a customer asked me to build a summing mixer with different flavours on channels so I though about a modular solution to let me adapt on each channel different “analogic colours” without having to elaborate many different pcb layouts.
Instead of building something super custom I tried to design something around COLOUR MODULES (the open source format around DIY world).
And the result was the first COLOURMIXER (V1.0).
This custom built unit has a Control room/MONITOR section and one of our bus compressors inside.
At the beginning of develop of the first colourmixer I designed a pcb with DIP components.
Each channels has THAT corp balanced line receivers/drivers (1240/1646) and a dual opamp to deal with colour module.
The balanced line drivers are used to take a direct output from each channel.
All the channels going to an opamp summing circuit.
Later I arrived at first “final” version with the option to mount THAT corp receivers/drivers or standard opamps in all the circuit.
Last month I built a unit with an elaboration of the previous concept: I put an each channel a colour module to deal with saturation/colour on each channel, a direct output for each module and a summing circuit in which I can use DOAs or opamps for summing and a colour module.
8 channels goes to “drive” channels and then into sum and 8 channels goes directly in summing stage in which I could deal with colour&drive/saturation.
The idea is to offer something to work with in
- tracking (preamp → input → direct out)
- in mixing (8 channels with colour and 8 without)
- mixing with 4 stereo stems but with the possibility to record tracks back into DAW with direct outs in order to make revisions
export in analog using 8 inputs with “drive” off + 8 clean inputs and maybe giving a touch of colour with the “Drive” in summing section
I have some PCBs of first prototype with DIP parts (THAT corp balanced line receivers/drivers (1240/1646) and a dual opamp to deal with colour module).
If someone is interested in them or into the complete project we could consider to make a PCB kit, due to the “open source” idea behind COLOUR modules.
Here you can hear it in action (first unit):
https://youtu.be/stuzLYlyMcICheers,
Alessandro/Side-b Studio
