Disassemble sennheiser md441
jakobz
Active member
Hi  :)
Im having trouble opening a md441.  I have removed the screw beneath the serial number plate and removed the Xlr connector. I have seen pictures where the entire side of the mic is removed. On my mic the side is loose and can be lifted slightly but it seems to be stuck up by the grill. I. Could probably get a little screwdriver in between and lift it, but I am a little nervous about using to much force. Am I missing something here :)
One of the wide sides (very likely the one where the screw was) slides up 5-10mm, and then you can remove it.
No probs :) Glad i managed to remember how that went, it's been a couple years since i've last had a 441 :D (ended up having to sell it to make rent... rough days back then)
