RCA 96-A from scratch
DaveP said:
The customer likes 4 in meters, simple as that and to be honest, that hood meter is quite ugly IMO.
No.....!  It looks amazing in person, and is the work of one of the foremost art deco designers in America!  But you're right, they are amazingly hard to find.  Custom to the Deluxe line amplifiers.  And.....the 96-AX does have the 4" meter.
DaveP said:
Its almost impossible to make exact copies, where would I get the transformers for example?
There was just a complete original set of 86-A transformers on ebay, FWIW.    They do show up, I've seen it several times.  But yes, if you go looking, you might not find, though you could find 'similar enough' original make units.  You have to enjoy the 'search and discover' though.
What I can do is use original tubes and keep the audio circuit the same and hopefully the sound will be pretty close too.
Unfortunately "The customer is always right".  I agree with Doug on the beauty of the deco style meter and concede the point that it was later made with the other style.
I saw that lot of 86-B iron too and though the price was reasonable I just didn't see myself building one.
Here's the best quality original picture I've found of an original installation, from the time of installation.    This has to be an actual print from the negatives RCA used for promotion.  Download the original size so you can see detail.
Note this installation is 'transmitter gray', equally common at the time but less common now since it went into larger installs that were more likely to see forced demolition by accountants, versus small stations where things just 'disappeared' upon retirement.
The PSU is above the amp too, which is the recommended mounting, and in fact, you can't rotate the hinged chassis out if you put the PSU on bottom as everyone now does.
https://www.flickr.com/photos/wmar_archive/9592239562/sizes/l/
Another 'Transmitter Gray' install, this one with the PSU under, but with a spacer panel in between.
https://www.gettyimages.com/detail/news-photo/technician-monitoring-equipment-in-studio-of-local-radio-news-photo/72400108
You can see the color here:
http://www.arizona-am.net/PHOENIX/KB7OCY/KB7OCY_op.jpg
The main compressor circuit is now finished, but not the side-chain.  At this point I thought it wise to test the amp to see if it was OK before proceeding further.
First I ran it up to full power before clipping, this surprised me as I was not expecting much from the type 89 tubes.  It managed to put a clean 24V rms across a 600 ohm resistor, thats +30dB! or 1Watt.
Next I checked the Signal:Noise ratio and at maximum output it was  -74dB unweighted.  The original quotes -68dB so I am very pleased with that.  Considering there is no NFB in this design, this is a great credit to the RCA engineers of the 1930's.
Turning to the frequency response, I tested this at a more sensible output of +4dB.  The input level was -2dB
I ran it from 10Hz to 30kHz and despite the dip at either end, it was still within +/- 1dB from 20-20kHz and this was with off-the- shelf modern transformers.  As this compressor is designed for some old school character, it looks like it will fit the bill.
Next job is to assemble the attack and release switches and connect the side chain.
The components are all fitted now and some pics will follow soon.
These very poor pics show how I modded the meter bulb holders to accept warm white Led's.
This is the original with a 6V bulb.
The spring connector was removed and the LEDs carefully glued into 5mm dia washers, with Araldite.
Longer leads were soldered on and covered with heatshrink tubing.
Then the LED assembly was glued into the lamp holders.
These LEDs work well in series drawing about 17mA which is just under the rated current.
Sorry for the poor picture quality, too busy to redo them, but you can see how it was done.
Amazing work Dave!
Would you mind sharing links to the exact handles you used for the chrome vent replicas?
Hi Alan,
The chrome bow handles came from      https://www.morehandles.co.uk/hafele-cordelia-bow-handle-107-66.html    In a pack of 16 so 8/side.
The cup handles were  from Amazon UK    Koofizo® Cabinet Cup Handle - Chrome Shell Shape Furniture Pull, 3 Inch/76mm Screw Spacing, 10-Pack
https://www.amazon.co.uk/gp/product/B07MQZRR5Z/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I very carefully cut the lips off then sanded flat on a sand paper sheet.
All the best
The lettering and sealing is now done, so time for the final finished photos.
Switch far left is GR on off so you can hear the difference.  Next switch selects between GR and the Balance test, which is adjusted with the next pot.  Normal attack and release switches.  Meter switch between Tube Test, GR and Output level.  Threshold, then meter zero and compressor on/off.  At the back there is a pot to set the B+ to 250V and a pot to set the GR tubes bias to -3.9V.
Here is what's behind the front panel.
Cover on and it needed a handle.
Full point to point construction with busbar.
This project is now finished and awaiting final set-up and test before shipping.
Thanks for your interest and support
Best
This is the compression I measured on minimum threshold.
Input to comp was +4dB,  non-compressed amplification line extended for reference.
The 96-A built by Dave arrived yesterday and my its gorgeous !!
It sounds fantastic and looks just as good.
I was quite bowled over as i unwrapped it !
The build, its so well made and the art deco look it just stands out now in my studio.
The tone is similar to the OP-6 Dave built me but this 96-A , like the graph Dave put up on this thread, has less low end and less upper highs. So its a bit more mid forward in its sound... which is a bit '' vintage ''.
And the compression is fantastic..... you can get up front vocals and also a nice laid back compression.
I am so pleased with it !!!!
As a user of Daves box's each week, i am so impressed with Daves builds... far better than allot of the junk out there.
A year later, after using this RCA 96a compressor every week (mostly) in the last year. I can say its one of my favourite units that Dave has built me.
The sound is quite frankly stunning. And the compression is versatile (which I wasn’t expecting).
Its sounds velvety and yet open sounding.
You can have grabby compression , with faster release / attack or stick on attack 10 and release 100 and its got this vintage character.
I’ve just used it on an album for a well known artist, that charted in the top five in the UK.
She recorded all her vocals for this album through this 96a , also Daves 241-76 mic pre as well ( and my vintage C12 ).  It sounds so good, I dont need to do any mad EQ-ing either !
Just wonderful and I’m grateful !
