32-4-2 Ch Each With Transformer 19" Rack Summ Box , What The Weight ?
r2d2
A-rea 51
Hi everybody ,
am i wrong  , or did I understand correctly about this summ unit  ?
https://heritageaudio.net/catalogue/mcm32/
cheers
Check out the user manual
https://www.heritageaudio.net/wp-content/uploads/2017/04/MCM-32-user-manual.pdf
Four audio  transformers are used in master section (in two 1073 type mic preamps), where passive summing is used for signals from subgroups.
r2d2 said:
passive pan  ?
Almost certainly. It is just about possible. I drew up a scheme for this some time ago. I will see if I can find it.
ian
I found it (see attachment)
  • BalancedPassiveMixerWithPan.pdf
ian
much thanks for post Ian ,
it mean that it require a 3 deck pot ?
(1 for in gain and 2 for L-R pan)
cheers
Ps:
sodderboy said:
Dang, I love their BT-500!
Mike
…...radio frequencies and electromagnetism  ( smartphones , wi-fi , blutooth , DAB , DVB , Military Transmissions , & co.)
are frying  the brains……
…check hair if they are normal or electrified ...
Ya was thinking about my console and do I want that module in the board.  It’s for playing a phone into a monitor section.  I was thinking the other way playing into a smartphone iPad and such so opposite use.    In post production ,  you have people that want to review some online spot all the time .  More useful for that to play into your system.  Making commercials is probably bad for your health also.  I’m glad to say goodbye to that profession.
cheers
Well if you want a dual concentric control then one pot has to be a single pot and the other a dual. If you were building one yourself you could use separate pots; a dual for the pan amd a single for the fader.
ian
ian
mor thanks for post Ian ,
from what the "MCM"  image show the knob in the center is the gain
ans the "ring" the panpot m,
(or i'm wrong ? )
cheers
Not necessarily. There is a way to use a single deck pot as a panpot...
...but I really wouldn't recommend it. Passive mixing is already pushing the limits of noise performance (for a large count of channels), you don't want to add more attenuation before hitting the active stage.
(or i'm wrong ? )
cheers
I think that is right. Neve used dual concentric controls a lot. The outer control has a hollow shaft for the knob. The shaft of the separate centre pot is fed through the hollow shaft.
