Low voltage after bridge rectifier
BluegrassDan
GDIY Supporter
Elizabethton, TN
What might cause very low voltage after a bridge rectifier?
I have a PSU transformer spitting out 220v, followed by BR, then typical CRCR. Voltage in to the BR is 220v, but  after the BR is like 6v max. I’ve changed out the BR and it tests correctly.
Bad transformer? Something else?
Strange! Maybe the battery of your multimeter is empty or the measuring device is defective? Did you check it with a second multimeter?
