3nity
Small mixer ideas!?
« on: February 21, 2020, 08:26:51 PM »
I need to build a small 2 stereos INputs to 1 stereo output.
I never looked into mixers before.. This are for my keyboards synths.
Thanks in advance.
Life is a path, death the destination.
boji
Re: Small mixer ideas!?
« Reply #1 on: February 22, 2020, 11:50:06 PM »
Active/Passive?  Room to grow?  Pan? Aux inserts? Mute? Define your constraints/needs.
3nity
« Reply #2 on: March 05, 2020, 10:35:08 PM »
Hi boji.
Need a solution to mix 2 keyboards signals.
2 stereo line input.
Mute switch for now.
Passive better.
« Reply #3 on: March 06, 2020, 04:31:09 AM »
Are the keyboard outputs balanced or unbalanced?
What will you feed the mixer output into?
fazer
« Reply #4 on: March 06, 2020, 10:27:21 AM »
What’s the budget?  You can buy a small mixer for 50 to 100 dollars that can do this.   It’s doubtful you can build something cheaper.   It use to be a build in mix fuction on some Roland keyboards to handle this especial with their modules.
Whoops
« Reply #5 on: August 27, 2020, 12:04:47 AM »
Hello 3nity, How are you?
You probably have your mixer sorted by this point, but just to let you know or someone else in the future that for Keyboards (unbalanced line level) this simple mixer circuit works great.
Having stereo is just a matter of having dual pots and double the schematic:
http://www.generalguitargadgets.com/pdf/ggg_mixer_sc.pdf
http://www.generalguitargadgets.com/effects-projects/boosters/mini-mixer/
Last post August 16, 2013, 12:39:20 AM
by chaellus
Last post September 30, 2009, 12:39:05 PM
by conleycd
Last post January 15, 2011, 10:40:19 PM
by dmlandrum
Last post January 19, 2019, 11:55:08 AM
by boji
