scott2000
Re: DIY API 1604 inspired mixer (16x8x2)
« Reply #100 on: August 02, 2020, 01:38:20 PM »
Gorgeous. :o
boji
« Reply #101 on: August 03, 2020, 12:34:18 AM »
Thanks guys.  Owe much of it to yall and gdiy. Much love.
boji
« Reply #102 on: August 09, 2020, 02:12:31 AM »
In the weeds... 8)
Direct out runs (pre-cleanup):
messy (but useful) wire wrapping:
« Last Edit: August 11, 2020, 07:07:23 PM by boji »
fazer
« Reply #103 on: August 18, 2020, 12:59:12 PM »
It is just old school wiring.  Not messy.   I'm dismantling my studio and looking at the wire work done point to point circa 1975.  Lots of spaghetti when its all done.   Wire tie or wrap is the only way to keep the bundles secured to the frame and stay put in place.
« Reply #104 on: August 18, 2020, 04:32:58 PM »
And when it comes wiring panels, old school tie bars are still the best:
scott2000
« Reply #105 on: August 18, 2020, 07:27:56 PM »
 :o cool
boji
« Reply #106 on: August 19, 2020, 06:16:47 PM »
Thank you for saying so. If perfection was paramount (ought to be) I'd of made jigs like PRR? posted few months back...
Yes!  Can't get much nicer than that--a structure meant to keep clean the runs in a superstructure.  Looks the best!
The leave no stone unturned approach, the over-thinking
Building me some Dunning-Kruger rainbow bridges!
I have a feeling Boji, that you'd like the project to go on for good
Quite the opposite- Came to terms with the fact I've never finished anything that has been truly objectively difficult.  Want to see if I can actually make something that intertwines unknown territory with maximum deferred gratification-- completion is critical for many reasons, most of which are psychological.
Edit:  I've also been scared of success in the past, have a problem with the spotlight, and have a desperate love for making music-- so there's fear and distraction at play as well... it's not all a 'grand rite of passage'- there's some bullsh*t floating around it too!  ;D
« Last Edit: August 19, 2020, 06:51:02 PM by boji »
boji
« Reply #107 on: August 20, 2020, 12:35:08 AM »
Distribution busbar well dressed and complete.
On to topside signal...
« Reply #108 on: August 20, 2020, 04:42:21 AM »
I searched tie bar, and found they're referred to as lacer bars as well.  Ian, yours look as though they must be tapped for a screw, then screwed in place from the outside of the back panel.  Neat option for keeping things... neat.  I came up with a method of my own when I did my back panel (with tons of XLR and TRS I/O connectors) but will try this technique in future.
Adam
Tie bars, lacing bars - the terms are pretty much interchangeable. These one I got from Canford Audio here in the UK. They use them on their own custom panels. I already had the panels from another supplier; i just needed the tie bars. You are spot on - the ends are tapped. I just drilled a couple of countersunk holes and screwed them in. As well as making things tidy and supporting the wiring, they act as strain relief on the connectors. The tie wraps shown in the pic are rhe commonly available type but they look a but too big to my eye especially compared to traditional lacing. I recently found some that are about half the width. They look much neater.
boji
« Reply #109 on: August 23, 2020, 11:45:08 AM »
Main, Group, & Aux VU buffers (circuit optimization courtesy Joe Malone):
« Last Edit: August 23, 2020, 11:50:27 AM by boji »
boji
« Reply #110 on: September 14, 2020, 04:05:23 AM »
Some boring updates:
Confirmed Mogami W2944 wire pairs perfectly with EZ or standard RJ45 connectors:
About 12 terms per ch to/from slots, logic & patchbay... (work!)
Using ratsound's supercat for CV, due to its braided shield and flexibility.
Works nicely for signal too, as a silicone-like inner molding and stranded nylon core keeps TP's separated. Easy to work with.
« Last Edit: October 01, 2020, 08:59:28 PM by boji »
boji
« Reply #111 on: September 30, 2020, 02:56:15 AM »
#4 Channel interconnect, 8 of 16 (Slot2 inserts/patch, A1 insert/patch, VU sends)
shabtek
« Reply #112 on: September 30, 2020, 07:13:01 AM »
maximum respect
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
boji
« Reply #113 on: October 01, 2020, 07:17:25 PM »
/salute Thank you Shab!
Never been excited about a wire delivery until today  ::)
Gold
« Reply #114 on: October 02, 2020, 12:13:36 AM »
I love that stuff. I only use four colors for four channels. I recently started using Mogami 2368 for unbalanced and/or shielded connections.
boji
« Reply #115 on: October 12, 2020, 03:18:14 AM »
Channel cables complete. On to group connects.
Underestimated lengths so had to use all the colors. ::) At least they'll be super easy to trace!
« Last Edit: October 12, 2020, 03:25:45 AM by boji »
boji
« Reply #116 on: October 29, 2020, 12:21:12 AM »
Bought a label maker
Final set of faceplates bascoated:
fazer
« Reply #117 on: October 31, 2020, 02:12:41 PM »
Your getting very close.   Maybe I missed a post.  Do you do the silk screen?
boji
« Reply #118 on: October 31, 2020, 06:32:13 PM »
Heythar Faze! I've just been in the weeds making group logic interconnects and coding up the VU meter led's.  Not so photo-interesting until complete.
The first few I used a syringe and nail polish, but I think I'll pay extra to have FPE backfill since I'm sending out for engraving.
Update: Cheap *** went the diy backfill route. Infill occasionally forms bubbles which requires a 2nd pass >.<  Should have done UV paint or bit the $ bullet; not a good use of time.
Thanks for your support man! Kinda sort of close. Still need to code-up and make cables for mute/solo logic and buffers, fader faceplates, integrate monitor controller. Once it's actually passing mixes I ought to build some aux returns, as there's 6 empty backplane slots available, but I reeeely need to get back to making music first!
Edit:  May need an additional PSU due to voltage drop. Tomorrow I'll install everything and see. Wish me a test that is smokeless and without incident!
« Last Edit: December 20, 2020, 03:04:21 AM by boji »
fazer
« Reply #119 on: November 01, 2020, 08:49:51 PM »
Oh please be a smokeless test may ohms law be kind to you.
Last post May 15, 2011, 02:09:08 AM
by mulletchuck
Last post June 01, 2018, 06:48:53 PM
by sahib
Last post November 12, 2020, 01:39:47 AM
by iprovlek
Last post February 19, 2021, 10:32:24 PM
by JW
