Desktop CNC Router Selection Help
« on: February 28, 2020, 11:33:58 AM »
Hello GDIY
my son and I have been looking into a small format router for some time.  With no first hand exp. we wanted to ask for thoughts on which is a good starter machine.
To start this would be used for our CTC prototype plates. Mostly etching as we are working to connect with Frank to source panels.
https://www.cancam.ca/product/d-11-minitron-desktop-cnc-router/
Here is what we are considering. Any thoughts, input on other options would be great.
Wall
If you are curious, you'll find the puzzles around you. If you are determined, you will solve them.
Erno Rubik
Re: Desktop CNC Router Selection Help
« Reply #1 on: February 28, 2020, 12:07:36 PM »
$3000 is a LOT of panels. I went down this route a few years ago for much the same reason - quick turn around prototype panels. I paid less than $400 for my machine. It was a lot of effort to get it going and to hook it up to a PC and to get the design data into a suitable format. Even then the results were less than satisfactory. i broke no ebd of drills and the thing was insanely noisy.
If you just want to engrave you might like to think about a laser version - very much quieter. I also looked at a chunky vinyl printer. This would allow you to make full colour prints of front panels and just stick them on. You could even include markings for where the holes need to go and then drill them by hand. Unfortunately the manufacturers were not able to guarantee the necessary accuracy so I never took it any further.
YMMV
« Reply #2 on: February 28, 2020, 12:30:11 PM »
YMMV
Noted. $3000 is a lot of panels and there is no substitute for Schaefer & FPE.
My wife suggested learning from a shared workshop of some sort in the future and build from there.
Erno Rubik
« Reply #3 on: February 28, 2020, 03:07:32 PM »
Maker Spaces or the equivalent often have this kind of gear you can use at reasonable rates. That might be a good way of familiarising yourself with the equipment, and  its pros and cons.
https://makerparts.ca/pages/makerspaces-in-canada
iampoor1
« Reply #4 on: February 28, 2020, 09:23:34 PM »
the problem with many of the budget CNC machines is that they really have very little rigidity, and the accuracy specs are based on the theoretical resolution of the motor drivers, not real world performance metrics. Remeber, milling aluminum is totally different than engraving wood or plastic.
If you are building just 1 project, I would just get all the panels fabbed.
I dont have my cnc machine setup yet, but I bought a cncrouterparts benchtop pro machine for milling panels. The sheer mass and rigidty of the machine (it weights about 250 pounds) was a huge concern for me., and when looking aat most of the budget hobbyist machines, it just doesnt look like they really offer much.
Also note that they do not even specify a spindle/collet runout spec for that machine. If you have 3-4thousands (which is not uncommon on the cheap Chinese spindles), that is going to seriously hamper your accuracy and cutting head life.
Most of the makerspaces near me offered LARGE cncc machines, but not accurate ones. I think milling and engraving aluminum panels is not exactly what most people have in mind when they see CNC machines. My local makersspace had a really nice 4x8 machine....with a bosch router as the cutting tool.  :o >:(
shabtek
« Reply #5 on: March 01, 2020, 12:22:11 PM »
FM Steve/Lazy Lizard did some nice panel overlays in plastic material years ago with manual pantograph engraver (I think) not sure if he cut a template first  or what but I recall it looking like pultec or antique hp test gear legend plates.  not cnc (unless you had the template cut cnc) but an idea for diy replication fwiw
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
« Reply #6 on: March 01, 2020, 12:47:04 PM »
Thanks for the help.
We had looked into various materials and even UV screening our own cards. In the end in was mostly for learning the ropes.
The concept of rigidness and vibrations had not even occurred. My old barn workshop would collapse!
Erno Rubik
Last post February 24, 2008, 06:03:22 PM
by flaheu
Last post July 24, 2008, 10:49:09 AM
by clintrubber
Last post March 22, 2012, 02:39:09 PM
by Grand Master Audio
Last post March 31, 2012, 04:13:28 PM
by peterc
