f0m3
Housing pins replacement
« on: March 14, 2020, 04:26:22 AM »
Hello,
i just bought a Grundig GBM 125 at ebay kleinanzeigen for 11€! Yay. It's said to be a beyerdynamic 260 OEM ribbon capsule (just one ribbon)
I had some trouble opening the microphone basket and the housing because its held together with little steel pins i had to push inside. Unfortunately i cant get the pins out, so they are lost in the plastic (maybe ABS) housing. One pin i had to bore out carefully so the hole is now a little bigger and will have to be filled (maybe epoxy).
The mic is working fine, got a new XLR cable, all insides were left as they were.
Any ideas how i could replace the pins so that it would be easy to reopen the mic? Like a glue that melts on warming  or anything similar?
f0m3
Re: Housing pins replacement
« Reply #1 on: March 14, 2020, 05:41:35 AM »
What do you think about something like this:
https://www.boesner.com/shopfunktionen/shop/fixogum?gclid=CjwKCAjwgbLzBRBsEiwAXVIygBcakPUsL2-y7p8ElQpw_ggdBJ9egu9JhwtqHJlv1eBwefDS7XXRaRoCYQ8QAvD_BwE#3829?RefID=PLA_200_15954_pla&id=15954
Nobody would through arround a ribbon microphone so the mechanical resilience doesn't have to be too big...
abbey road d enfer
« Reply #2 on: March 15, 2020, 08:33:28 AM »
Hello,
Can't you drill and tap? Very small screws and taps are available from modelling shops, even on amazon.
f0m3
« Reply #3 on: March 15, 2020, 08:56:44 AM »
Good idea I'll give it a try. Dont know how good such a small tap would work in ABS.
abbey road d enfer
« Reply #4 on: March 15, 2020, 11:38:30 AM »
In the same dimensions, there are self-tapping screws. They have a larger pitch and thread depth, so may be more suitable for plastic.
Last post September 20, 2004, 08:00:29 PM
by
Last post September 14, 2005, 01:15:29 PM
by rodabod
Last post October 13, 2005, 04:04:52 AM
by ioaudio
Last post October 31, 2005, 11:11:34 AM
by bradb
