I'm in year 12 of this build. It wasn't really a console until recently. Shaker Desk is an A/B Path console for mastering directly from open reel tape to lacquer master. A record is a single spiral from the outside to the inside of a disc. It must be recorded in a single pass as there is no way to drop in or edit. This means that to have different settings for each song on the side you either have to change settings in the time between songs or have a separate setup. This is the purpose of an A/B path console. You can set up the A half for song 1 and the B half for song 2. When you get to song 2 you change to the B half of the console. Then you set up the A half of the console for song 2. You flip flop this way until the side is done.
The lathe automation needs to see the signal about one revolution before it gets cut. This is called the Preview Path. The signal that gets cut is called the Modulation path. This means each half is four channels. Modulation Left/Right and Preview Left/Right. Although it looks like a two channel console it is actually eight channels except for the monitoring and meters.
I've been posting the individual pieces in the appropriate sections. Until now it hasn't really been a console. Now as I'm closing in upon completion I figured I'd start this thread.
I spent the last couple of days installing the processing chain in the B half of the console and working out some kinks. I spent today listening and playing with it. I officially pronounce it a console.
The signal path for both the A and B halves are the same. Input Amplifier with source select, level adjust and process insert chain.
The process insert chain is TFEQ(Igor Sontec), Pico Compressor, Barry Porter EQ, DAOC, Maselec MLA3.
The process chain is inserted in the transfer path. The transfer path is Input Amplifier with Maselec MDS2 HF limiter permanently inserted. HPF/LPF, Elliptical EQ, Output Amplifier with level adjusters and a fader.
The Output Amplifiers feed the crossfader which can select either A, B, or Crossfade.
The monitor controller is made of two Broadcast Tools 16x2 relay switchers. One switcher is for the Modulation Path and the other is for the Preview Path. I can monitor directly from any source. Directly of the DAW D/A, 1/4" or 1/2" tape machines and two Aux positions.
I can monitor after the input amplifier for a level adjusted version of the source. I wired the Input Amplifier so that the Monitor signal is picked off before the HFL Insert and the Process Chain Insert.
You can monitor after each Output Amplifier and you can monitor after the Crossfader as the Main Out.
There is also a lathe remote.
This is the Processing Chain.
This is final face plate for the TFEQ. The BPEQ needs a final faceplate. I need to redo the center section face plates. The HPF/LPF will be removed. It is Neumann HT75's that are on their last legs. I'm going to do a stripped down HPF/LPF with only 40Hz-18dB/Oct and 16K Hz-18/dB/oct. I will locate the PCB's inside the EE chassis below it. That will open up 2RU for future expansion.
The meter panel will be redone. I've decided to use giant Weston VU meters and an RTW plasma PPM.
I spent the last couple of days installing the Processing Chain and working out the kinks. Today I got to really listen and play. It's everything I had hoped for. I'm quite pleased with the sound and functionality.
