neumann w 495 stb eq - how do i connect power supply?
voodoostudio
New member
Hallo,
i have a neumann w 495 stb stereo equalizer,
i did find the pinouts and i understand how i can connect xlr cables,
but i don't understand how the power can be connected,
on the pinouts i only see one pin thats connected to +24 volts,
if i buy a simple 24v power adapter i have two wires
can you please explain me how i can fix this?
With friendly regards,
Jeroen
  • w495 (1).pdf
i have  a "pin adapter" , there still are some wires connected but i'm not certain that these are all at the right spot
for example on the 4th pin from the left i see there are still 2 wires connected: (this should be the +24 volt)
(white ............  brown ...............blue+blue+red .................. red+red
for what reason would i connect two wires to the +24v connector?
hi,
thanks for the info,
and if i'm correct pin 15 "0v"  is the ground of the xlr output 2
so these two are connected together,
do i need to connect all the other "0v"  to pin 15 ?
No, they are internally connected.  You may test it using a DMM. "0" at audio pins are used for cables shield connecting.
