echoplex Well-known member Joined Jun 29, 2011 Messages 195 Location Germany Mar 22, 2020 #1 hi there, does anyone here know the IC called ep2015cn from élantec? thank you in advance
PRR Well-known member Joined Jan 30, 2010 Messages 11,143 Location Maine USA Mar 22, 2020 #2 MPQ3906 THAT 320 http://www.thatcorp.com/300-series_Matched_Transistor_Array_ICs.shtml http://www.thatcorp.com/datashts/THAT_300-Series_Datasheet.pdf
echoplex Well-known member Joined Jun 29, 2011 Messages 195 Location Germany Mar 28, 2020 #3 PRR said: MPQ3906 THAT 320 http://www.thatcorp.com/300-series_Matched_Transistor_Array_ICs.shtml http://www.thatcorp.com/datashts/THAT_300-Series_Datasheet.pdf Click to expand... thank you so much! you think they work as a drop-in replacement for the ep2015cn? will check the ddatasheets now you posted
