BluegrassDan
1:5 mic pre input transformers
« on: March 24, 2020, 09:50:18 PM »
Okay guys. I'm really liking the sound of the Cinemag 1:5 mic pre input transformer on my tube preamp. It seems to be middle of the road in terms of hi-fi with a hint of coloration.
Just out of curiosity, do you all have any other 1:5 recommendations? For example, going in both directions toward either neutral or colored. It would be nice to have a couple options for either super-fast transients versus big, fat vintage.
Anything that's off the beaten path and lesser known? Would need to be modern production and available.
L´Andratté
Re: 1:5 mic pre input transformers
« Reply #1 on: March 25, 2020, 06:55:46 AM »
This one:https://groupdiy.com/index.php?topic=64069.msg811214#msg811214
Very simple dicrete mic pre, low noise, beautifully coloured sound!
(It´s not a fuzz box, you can make clean recordings with it too)
« Last Edit: March 25, 2020, 07:02:12 AM by L´Andratté »
"Why not get an assistant to work the faders? Real vintage! And maybe cheaper... ;)"
rackmonkey
« Reply #2 on: March 26, 2020, 03:36:01 AM »
Jensen makes the JT-13k7-A. They also make a 1:4.8 input called JT-13k6-c.
Edcor makes a 1:5. No can on that one. You’d have to shield it yourself.
Sowter has one or two as well, One is a 1+1:5 (9045).
OEP may have one, Never bought any of their stuff.
As far as modern production, “off the beaten path”, I got nothin.
« Last Edit: March 26, 2020, 03:41:07 AM by rackmonkey »
Whether you think you can or you think you can't, you're probably right.
RuudNL
« Reply #3 on: June 07, 2020, 01:04:14 PM »
I have been using Sennheiser TM003 transformers with great success in the past. (1:2.5 or 1:5)
There is a solution for every problem!
http://www.vansteenisaudio.nl
« Reply #4 on: June 07, 2020, 01:23:04 PM »
There's also Lundahl.  Having said that, your CMMI-5C is a nice choice.
« Last Edit: June 07, 2020, 05:02:02 PM by Winston O'Boogie »
Jeffrey Toobin: "This is the most embarrassing week" ever.
Rudy Giuliani: "Hold my pants..."
rackmonkey
« Reply #5 on: June 11, 2020, 12:23:01 PM »
Here's a different one for you, Dan. Check out the post in Magnetics about the A-10 clone from Crimson. They can customize a 1:5 based on the A-10 design for about $75 in singles. Probably cheaper in quantity.
You could also check out their standard input. I think 1:10 and 1:8 are stock options, but I'm betting 1:5 would be the same price.
Just a thought
BluegrassDan
« Reply #6 on: June 12, 2020, 01:19:13 AM »
Just a thought
That does seem very interesting. Thanks for the lead!
Last post September 16, 2004, 04:29:40 PM
by JPrisus
Last post March 23, 2006, 03:39:08 AM
by moamps
Last post July 16, 2009, 11:25:26 AM
by sunyata
Last post January 09, 2010, 01:47:55 AM
by Adky
