A Multiband GSSL !
Cardinen
Italy
Hi all,
For some time I had this crazy idea in mind,  inspired by this thread https://groupdiy.com/index.php?topic=70580.0
The idea was to make a multiband compressor with 3 Gssl and a simple 6dB/Oct crossover with variable frequency.
I used some old gssl pcb (rev.7) with a few mods:
- THAT 1246/1646 for in-out
- Relay True Bypass  and Mute
- Adapted Attack and Release time for each band
-  Make up gain 5dB with 0.5dB steps
- Ratio 1,5:1 added
- LedBar meter reduction
- Sidechain link between compressors (still to be done)
The crossover is based on single pole R-C filters with 2 buffers at input and output for each band, the frequency is changed by the resistor values;  At the moment i have only set a fixed position at 100hz for the low and 5khz for test purpose.
I've used super matched pairs of Styroflex and Polypropylene caps for the filters.
I admit that at the beginning i was a little skeptical about this project, as a mastering engineer i was afraid of phase issues or flat response of the crossover, i have to say that when I listened to it the first time all the fears passed  :)
I'm very happy with the result, the unit is very clean and the crossover is imperceptible with no gain reduction or make up gain,
in the past I have happened to work with the Maselc Mla-3, and i have to say the workflow is very similar.
It took me several months of work to complete it, it was a fun but also frustrating project at times ... but hey! this is DIY!  8)
This is great but it feels like you would want more control over narrower bands. Still I am certain it would be a great tool.
Yes bands could be narrower but i find it very useful this way for tame an harsh hi-hat or stop an uncontrolled sub, it’s a great tool.
Wide bands give me good feeling about transparency
Gold said:
Looks great. I’m glad to hear that style crossover is transparent.
Thanks Gold  ;)
Rob Flinn said:
Looks great.  Did you not think of adding the turbo boards ? With my single band version I find myself never using much out of turbo mode.
It was not planned to add turbo boards on this but will see in the future...
A 6dB/oct filter is the only order that will do a perfect mathematical sum. Steep filters won’t . For a narrow frequency band you would need steep filters.
For frequency dependent compression of a narrow band I think a dynamic EQ would be a better choice. That way you can dial in what you want without using steep filters.
