Hi mates,
I finished a drip U73b, and I have this issue that I can not understand.
The 2 first release times (fastest ) are working well, but when I use 3rd, 4th and 5th release times, the signal got compressed by default like 15db, and the needle stay at this point..like no attack time (needle stays at -15 on the meter even with no sound passing the unit) and no release (the needle never go back to 0) same issue on 2 channels, so it does not seems to be a short or a bad connection.. any idea ? Does anybody have the same issue ?
My second question concerns the calibration. Is there any starting point for all these trimmers and even for the threshold )
Last question : when looking at the documentation, I saw that the limit mode is about -10db than the compressor mode, no comparison can be done between the 2 modes. Is it a problem if I use the « cathode » trimmer to obtain the same level on output ?
If you have any info on any of this, thank you very much
Hugo
