Ok, an update-
Major breakthrough, I have the varicom working, its not pretty and its a long task to get it working I have to admit but I got there in the end.
FYI it sounds amazing so well worth persevering those who have bought this board, and whilst there may be discussion in the group about reverting to the original release time settings this works fine with the FC time constants and rocks. Will be making a video over the coming days and will post here.
Firstly, as promised - if you are using the Sowter transformer on the main board switch red and orange wires they are the wrong way round, fairly sure it's them
So - in order to get the varicom to take over control it is imperative to insert 10meg resistors into BOTH the attack (R80) and somewhere into the release path (I have inserted mine between the 'time' sma's from the main board to the front panel pcbs). Then I have returned the varicom 'source 1&2' sma's back to the 'time' sma on the main panel by using a T-junction sma connector. Also in order to do this I had to take out the ribbon cables and do much of the connections via sma although there is a problem and bypass and using the pilot light 6v if you need that for your VU lamps so I used some dupont wires for those instead from the pin sockets.
As for switching in the 10Meg resistors I did a bit of my own botch job on some practice pcb boards. Firstly you need extra 6V to activate the varicom board on its front panel pcb as well as activating some relays to switch in your 10M resistors in the paths you have intercepted.
A lucky mistake I made was to have the varicom on switch go in two directions, one drops in the 10Meg at the attack and one doesn't, the latter makes the varicom do something quite interesting and distorty to the attack, which is kinda fun. When the switch is in the middle the varicom is off.
All in all this is a really versatile unit and very interesting. the Varicom is really fast and punchy on the attack. As I said I'll rock a video of this real soon and post it up here.
Oh by the way whilst I'm waiting for the Sowter 1377's I have bridged the 9375 with a 47k 5w resistor and changed R47 to 330R, it has given me 1.8v or thereabouts.
Here's a pic of the inside
Lee
EDIT: HERE'S A VIDEO LINK.....
https://youtu.be/H4nMj4J7rhE ,,,,,ENJOY!
