pstcho
EZ1290 with mods
« on: April 08, 2020, 08:07:15 AM »
Hello guys, after several days of search i realize i cant make it with the infos i found
I am trying to finish at the moment ( quarantine time ) a lof of different projects
I wanted to finish my EZ1290 and though to integrate the GPultec that i never finished ( missing transformers ) as a filter board
Do you think it could be added easily lets say just before the output trimmer of the EZ1290 without having to mod too much the pulteq filter board ?
Also id like to add aled meter for the input and output sections of the EZ1290, can i trake the signal straight on  C1 for the input and  output B of BA183 / AV ( just before the output transformer ), for the output  ?
Thanks very much for the help, i dont have a lot of education in electronic, just quite a lot of experience diying stuff
Rocinante
Re: EZ1290 with mods
« Reply #1 on: April 09, 2020, 12:46:34 AM »
Yes to the led meter, no to the Pultecs. You could incorporate a Neve hpf easily enough though. Honestly I would just make the ez1290 and make an eq you want afterwards. The ez1290 is a fantastic mic preamp but is very sensitive and introducing outside elements makes it that much harder to troubleshoot. There are many  great eq's you can build on this forum, some have just hpf and lpf. Don classics also has the 1073 mic preamp and eq. Or build a G-Pultec or poor man's Pultec. Both are incredible EQ's.
If there's a harder way to do this, I haven't found it yet.
pstcho
« Reply #2 on: April 09, 2020, 01:34:53 PM »
thanks a lot for the reply
do you think taking the signal for the meters where i mentioned can work, or it can afftect the work of the preamp ?
EZ1290 finished
Started by Benny « 1 2 » The Lab
Last post August 24, 2009, 04:49:23 PM
by Audiotronic
Last post April 25, 2009, 07:23:43 AM
by rodabod
Last post November 26, 2011, 07:10:36 PM
by a zombie
Last post August 31, 2009, 11:18:55 PM
by 3nity
