Dibao Transformers
I don't know how the specs compare with a Lundhal but 1% distortion at 50Hz at +18dBu output is not very good in my book.
for an output transformer.
Also, the case seems to be made of copper which is very much cheaper than the  mu-metal used in the Lundhal and also it useless at screening magnetic interference which is essential in a mic input transformer.
Edit: and at $57 each they are not much cheaper either.
There's several Chinese companies claiming to make good 1527's, e.g.
https://www.aliexpress.com/item/32981126165.html  - probably there's just a single OEM and a lot of sub.brands
but as Ian points out, they don't care much about magnetic shielding, which is a very important parameter - just ask anyone fighting with the OEP-type transformers..
/Jakob E.
/Jakob E.
But to give them their due, OEP do offer proper mu metal screened versions.
