Studiogearlover
- Joined
- Mar 14, 2017
- Messages
- 178
Hey Guys
I have an EL34 amplifier with cathode biased output. I have been working repairing this for quiet a while. It hums like crazy when the volume/gain control is fully down and this hum does not change if I turn the controls.
Would you suspect the EL34s ( i have no history of these tubes). ? They are not red plating but if I poke one of the tube with my finger I hear something is buzzing inside the tube.
OR a bad ground connection somewhere? I've poked around with a chop sticks and no change.
New rectifier tube does not change anything. Preamp tube swapped, no change.
Before I spend money on a new set of EL34s could you please guide me what else to check?
1. filter cap changes
2. film caps changed
3 resistors checked
4. switches and transformer checked
5. soldering checked
6. tube sockets tightened up and cleaned
7 bias resistor and coupling cap changed.
8 heater wires are twisted
Its a home built amp (not by myself) schematic is not accurate what I have for it. The amp has: GZ34, EF86, 2x ECC83 and 2x EL34 output tubes.
thanks for your suggestion
3 resistors checked
