Studiogearlover
- Joined
- Mar 14, 2017
- Messages
- 178
scott2000 said:Exploding speakers doesn't sound fun. I hate when that happens... so does one of my dogs...
abbey mentioned very early in the thread, about your heaters and, I too am curious about how they are grounded. Your description is confusing and, I'm not sure your drawing is 100% right. I make little errors all of the time when trying to trace things out...
There's always something when I go back and look again it seems.....
Anyway, it would be nice to see how the circuit is wired with respect to the heaters at least. I'm not sure how it affects everything with the way that 1/2 ecc83 is grounded ... if the other tubes aren't? maybe someone else knows...
I was thinking pin 9 may not need to be grounded but rather complete the circuit since 4&5 are tied....maybe ground the entire heater circuit with a couple caps or resistors...or pot (like the original drawing)..... Guessing it's wired for 6.3v....
Also, I'm not sure what the school of thought is on how to treat the unused triode.... I see the anode is floating... Don't think it matters but, the other pins are sort of wired strange....like an after thought.... The grid and cathode resistors etc still there.....
That 60k resistor is confusing too.... I still struggle with load lines so, even if I could figure out what is going on in the drawing, I wouldn't know if it's optimal.....
Hopefully you'll get some more help....
I know it stinks to have to redo things but, in the end, it really doesn't take too long and you'll feel better about making sure everything is right. I have some hokey looking stuff too and, although I know it's safe and works, I'd be hesitant to share or sell anything to anyone I didn't know or trust not to hurt themselves......
yeah .. i might start and re wire the heaters... pulled out all the tubes left in only the GZ34 and the EL34s... I hear some zap zaps electrical sparks some where but can not see where this is coming from. Its not a loud spark, a smaller spark... could be the heater wiring somewhere shorting? or touching something ?
Thank you for your help and suggestion...
