Can anyone provide any information on how the X-10 remote modules work?
specificaly the communications that goes from a controler to the main X10 module that plugs into a recepticle...
the reason I ask is because I use them on a reef tank... the problem is that they are quite susceptible to interference... im pretty tired of dealing with it and would like to hard connect some relay switched outlets directly to the controller...
the thing is that I need to know how the communication part works... im assuming its a form of serial communication that ties into the master X10 module?
basicaly I would need to build an interface that can decode the signals in order to trigger the relays...
thoughts?
thoughts?
