So I've been staring at the 525C for a while today and I have a couple of questions.
I'm trying to figure out how the ratio works out - why limit is 20:1 and compress is 2:1.
If you consider the "ceiling" to be set to max, the sidechain input shorts past R18 on the original schematic, and then the only change to the sidechain between the two modes is the gain around the op amp. It changes from roughly 48 dB in compress to 54 dB in limit.
If you wanted to get ratios between 2 and 20... would you just change the gain on the driving amp accordingly?
