Been in the last days in an awful and painful discovery trip of the difficulties of making Thunderbolt (TB) working with newer PC machines using Windows 10.
Decided to share some info so I can help other in the future.
If you have Audio peripherals that use a Thunderbolt connection (I have 2x UAD Satellites and Focusrite Red 4 Pre) and want to have a new Windows PC built:
- Buy a Motherboard that states Thunderbolt in the Internal I/O Connectors or has a Thunderbolt port on the back.There's not a lot of motherboards with this, there's just a few.
Remember that having an USB-C port is not the same has having thunderbolt.
Although in latest PC's, Thunderbolt 3 (TB3) will come with an USB-C connector, USB-C is just a connector and can be used for different things. So don't think that because it has that USB-C connector that it has Thunderbolt integration.
Same connectors different things:
If the motherboard doesn't have a Thunderbolt port on the back,
only a few Gigabyte have, you have to get a motherboard with a thunderbolt connection in the I/O internal connectors
and buy an extra PCi card that will connect to the PCi slot and also to the thunderbolt on board Header.
Don't make the same mistake as myself and many others that though being PCi was the only thing needed, no, you need to have a thunderbolt header on the motherboard also.
Your Audio devices are probably TB1 or TB2 (both with Mini Display Port connector) . The computer will have TB3 (USB-C) connector. So you still need a converter outside the computer for TB2 to TB3 conversionTB1 and TB2 are Retro-Compatible
There's only 3 that I know in the market:
Startech Thunderbolt 3 to Thunderbolt Adapter (Product ID: TBT3TBTADAP) -
80 to 120€
Kanex Thunderbolt 3 to Thunderbolt Adapter (Product ID: K170-1051-BK6I) -
The Apple Thunderbolt 3 to Thunderbolt adapter (Product ID: MMEL2AM/A) -
56€UAD says "has been found to be incompatible with certain Windows systems in our internal testing. As a result, we do not recommend this adapter for Windows Thunderbolt systems. "
For people with UAD systems read this:
https://help.uaudio.com/hc/en-us/articles/205927089-Apollo-Thunderbolt-Connection-Info-https://help.uaudio.com/hc/en-us/articles/215731443- Current Z390 Motherboards with Thunderbolt 3Gigabyte Z390 DESIGNARE Intel Z390 (TB3 port on the back, no PCi card needed)
Asus PRIME Z390-A (TB3 header , ThunderboltEX 3 card needed)
Asus WS Z390 PRO (TB3 header , ThunderboltEX 3 card needed)
Asus ROG MAXIMUS XI EXTREME (TB3 header , ThunderboltEX 3 card needed)
Gigabyte motherboards with TB3 header, GC-TITAN RIDGE (rev. 1.0) pci card needed:
