Sometimes the simplest things can give us the hardest of troubles. The top row of the Helios uses 15 pin Painton connectors for the majority of the passive equalizer modules. There are a few exceptions. These are the same connectors used in Painton Faders.
Some day I will post more photos of the console from over the years. Currently the top row has most of those Painton connectors removed, and that is how it came when I bought it.
I decided the first step for this new chapter in the restoration was to put in the replacement paints I bought a while back.
Yesterday I tried to loosen the nut on the rack panels that had these replacements on them, and then SNAP! The mounting nut and screw broke out to the connector.
...Guess I got to glue that one...
I then added WD40 to all of the nuts and let it sit for a day.
Today I placed a NOS male into the female connector to try to brace the lug in place, while ever so gently trying to loosen another nut, and yet again...SNAP!
The photo attached shows the snapped connector from yesterday on the left, and the one I tried to loosen today on the right. I have tape holding the broken bits in place. It appears the plastic is so thin on the edges that it cannot take any torque whatsoever. Granted these are old and the plastic may also be brittle, this thinness still doesn't help. I may give it one more try with attempting to clamp the connector on it's sides with a woodworking clamp and seeing if it the pressure will prevent it from breaking.
If anyone has any suggestions on how to save these or have had to deal with instances like that please feel free to share your experiences.
