CAPI 2-Stage Line Amp
« on: April 29, 2020, 01:58:53 PM »
Hi guy !
I've been looking for a build thread, but I found no one. Does my surch skills are too weak ?
I'm planning of using 4 as input for a summing mixer I've started ammost 4 years ago
No fader, nothing, just strait debalancing cards
Does someone have the BOM & Schematic for it ?
Many thanks
Re: CAPI 2-Stage Line Amp
« Reply #1 on: April 29, 2020, 02:09:54 PM »
And I do actually have an other question !
Is there any possibility to have more gain on the second channel ? To be able to compasate the make up gain for a passive EQ (type EQP or Baxandal)  8)
Rocinante
« Reply #2 on: April 29, 2020, 05:00:45 PM »
I have schematics for a 2520 DOS line amp with pan volume and mute functionality. I used it in a Neve ended mixer I built using 990s and app992s. Worked a charm.
If there's a harder way to do this, I haven't found it yet.
« Reply #3 on: April 30, 2020, 09:06:23 AM »
Actually I'm really looking for a way to debalancing the signal before the 2 ACA BO summing card :)
I thought the CAPI 2-Stage line amp was the best option for this ! To get the 2520 color as well !
« Reply #4 on: May 06, 2020, 11:19:39 PM »
Bump! I am looking to do the same thing. If anyone has anymore info on this please contribute. I am looking to do a simple 8 input to 2 output summing box with transformers and op amps in every step of the way. As simple as it can be.
Justin Heron
Artist / Recording Engineer
« Reply #5 on: May 07, 2020, 12:08:50 AM »
Do you mind sharing?
fazer
« Reply #6 on: May 07, 2020, 12:44:34 PM »
The api line amp can be/ is U.N. balanced.  The output transformer can be run unbalanced out. Capi makes various PCb Cards that make building this thing cheap in my estimate.   Have you looked in the tech section at API schematics.   Part of the API sound is the multi stages in my estimate with transformers everywhere and the 2520.   Also having prefade insertion so adding the booster fader is  the second stage output. It allows a nice hardware compressor in the circuit which is a must for me.
« Last Edit: May 15, 2020, 12:40:21 PM by fazer »
fazer
« Reply #7 on: May 07, 2020, 04:51:34 PM »
I don’t see the ACA’s in api tech section.  Could have sworn it was there.  Anyway CAPI would have info on it and a build kit.
Last post March 31, 2021, 04:05:02 PM
by Jroq82
Last post April 17, 2018, 02:00:32 PM
by BricktopRecording
Last post May 30, 2018, 10:40:48 AM
by eternal slang
Last post April 29, 2020, 02:14:42 AM
by rackmonkey
