This post is related to my modular tube pre amp system
https://groupdiy.com/index.php?topic=67518.0I post it here because this is related to some specific transformer combos.
Recap: I've built a modular pre amp system based on Ian Thompson-Bell's TwinLineAmp.
The transfomer combos are
Module 1 Sowter 1948 1:10 IP, Sowter 1461 2k4:600 OP
Module 2 Sowter 1948 IP, custom wound ElectroMag 2k4:600 OP (there is a thread about this transfomer in this forum)
Module 3 OEP A187A15C 1:10 IP, EM 2k4:600 OP
I tried the OEP because I was annoyed about the long Sowter lead time (six weeks at that time, 12 weeks nowadays)
The OEPs are available within two days so I gave them a try.
I've recently discovered RoomEqWizard REW, so here are the measurements.
EDIT: measured with Antelope Orion 32+, amps set to line level input
First freq response: Sowter/Sowter
Sowter/Electro Mag
OEP/Electro Mag
All
Conclusion freq wise: the Sowter/ElectoMag combos looks most promising, the OEP/Electromag is not so bad, but IIRC the
THD was much higher compared to the other combos (0.1% for Sowter IP compared to 0.5% for the OEP)Edit: wrong, see below
