Kid Squid
WANTED - any old lengths / bits of ISEP rail
« on: May 01, 2020, 06:45:02 PM »
Hi all,
Just seeing if any of you have any lengths / pieces of ISEP rail that you would like to sell / trade ?
I normally get from Martin at SRS, but just popped into my mind out of curiosity really !
Steve
It is not the same as 4+12, nor is it the same as 4+8, but 4+12 IS the same as 4+8+12....
http://www.facebook.com/LazyLizardLabs
Re: WANTED - any old lengths / bits of ISEP rail
« Reply #1 on: May 02, 2020, 07:17:21 AM »
Hi all,
Steve
Just out of interest, do you tap the ends yourself?
IAn
Kid Squid
« Reply #2 on: May 02, 2020, 03:07:48 PM »
Yes Ian. The newer version of the ISEP has a hole already centralised running through the extrusion. Which makes tapping it a doddle. In fact, Martin will cut the lengths to correct bucket size, pre tap with M3.5 ( not 4BA as original) and satin finish the lengths.
The old ISEP is a bit of a pig, but I have made a jig in the past to centralize the pilot, drill on a pillar drill, then tap with either a 3.5mm or 4BA spiral flute tap, using a paraffin mix for cutting compound.
Steve
« Reply #3 on: May 03, 2020, 10:36:13 AM »
Steve
Cool. I use SRS a lot. They are a great company and Martin is a great guy.
« Reply #4 on: May 06, 2020, 10:01:57 AM »
Emailed about ISEP rails.
Kid Squid
« Reply #5 on: May 13, 2020, 10:47:46 AM »
Cheers Ian !
Last post October 02, 2005, 05:01:56 PM
by bcarso
Last post June 24, 2008, 11:11:21 PM
by Svart
Last post March 31, 2012, 09:15:39 AM
by Balijon
Last post December 06, 2019, 09:55:19 AM
by JohnRoberts
