WANTED - any old lengths / bits of ISEP rail
Kid Squid
Port Toilet, South Wales
Hi all,
Just seeing if any of you have any lengths / pieces of ISEP rail that you would like to sell / trade ?
I normally get from Martin at SRS, but just popped into my mind out of curiosity really !
Steve
Kid Squid said:
Hi all,
Steve
Just out of interest, do you tap the ends yourself?
IAn
Yes Ian. The newer version of the ISEP has a hole already centralised running through the extrusion. Which makes tapping it a doddle. In fact, Martin will cut the lengths to correct bucket size, pre tap with M3.5 ( not 4BA as original) and satin finish the lengths.
The old ISEP is a bit of a pig, but I have made a jig in the past to centralize the pilot, drill on a pillar drill, then tap with either a 3.5mm or 4BA spiral flute tap, using a paraffin mix for cutting compound.
Steve
Steve
Cool. I use SRS a lot. They are a great company and Martin is a great guy.
