fallout Well-known member Joined Jun 3, 2004 Messages 910 Location Caldwell, NJ May 2, 2020 #1 I just scored 2 Collins HS-50 transformers on the cheap. The primaries are 10k and the sec. are 600 ohms. I thought these would work well in an MEQ-5. Is there a problem with a 10k primary as opposed to the Triad HS-50's 15k primary? Thanks! Attachments s-l1600.jpg 134.6 KB · Views: 11
shabtek Well-known member Joined Jun 8, 2005 Messages 2,375 Location midwest usa May 2, 2020 #2 should work ok, . its 4:1 not 5:1. this is not a Triad hs-50. frequency response might be better than rated with no dc.
