Replacement capsule for Rode NT1a
Hello from France.
The capsule of my Rode NT1a is dead, I want to replace it, but I ask myself the question :  with which capsule, Type K47 or K67 or K12 ?
The new capsule at Rode costs € 150 in France... The cricuit is in CMS and relatively effective, I only want to replace the capsule.
Do you have any recommendations ?
I looked at the RK47 and RK12 at MP, the AK47, AK12 at AA, the Maiku are a bit expensive, I found a supplier on Alibaba who seems to make quality capsules, but I don't want to order 10! Thank you in advance.
I would like that my budget will not be disproportionate to the price and the original quality of the microphone. This is also an opportunity to test, I already have some large diaphragm condensers : Gefell um70s with an M7 rebuilt by Thiersch & Grosser, Oktava MK219, Rode NT1 mkI, Tbone SCT700...
michel_olivier said:
I looked at the RK47 and RK12 at MP, the AK47, AK12 at AA, the Maiku are a bit expensive, I found a supplier on Alibaba who seems to make quality capsules, but I don't want to order 10! ..............
You can now buy edge individual terminated capsules  from AliExpress :  https://tinyurl.com/aliexedgeterm
Normally the edge terminated  style are only from Alibaba - in 10 off minimum quantities.
Hey !
I do have change the capsule in mine.
I have put a ck12 capsule from beesneez, and change the capacitor to some vintage yellow mustard as well
It sounds awesome !
I would recommand the maiku ones ! They’re bang for the bucks !!
Greetings from France ! ;)
Thanks! Which cap do you replace ?
I do have the old one, the creamy grey version.
Which one is yours? Old one or the metal grey one ?
If so I guess their is no mod to make on the circuitry.
Here is a post from Jim Williams on GS
« Lucky boy. You have an original NT-1A.
I designed it with super low noise Hitachi transistors and a Siliconix rf jfet. As you can see it has German Roederstein metal film resistors and Wima polypropylene film caps. As it is there is little to do to improve it. It was built "modified". Peter Freedman did try to use lesser quality parts after the design but elected to use the quality parts I designated as they also heard the improved sonics from those parts. The NT-2 was repriced from $699 to $749 to include the quality parts.
Since then, competition has been fierce. Peter elected to lower the production costs of the Rode line so that's when the good stuff was chucked for all low cost surface mount parts. Those are the Rode mics you see today.
There are no frequency feedback nets in that design. There are a pair of 470 pf caps at the base of each Hitachi output transistor to ground that you can increase the value of to lower hf bandwidth. Try 1500 or 2200 pf.
The capsule is an odd duck with it's metal disc. It has no coating on the rear so it's cardiode only and has very low self noise.
The same design and circuit was also used in the original NT-2 mics but only that capsule is different. It also had a switch to add the rear diaphram for omni patterns.
Jim Williams
Audio Upgrades
It's a NT1a for which I need a new capsule. It's a later version than the white one (I've got one too). It's a CMS circuit version, so it's difficult to upgrade the components...
If my memory serves me right, the Rode NT1a includes a centre terminated 'K67' type capsule.. and uses a polarisation voltage of around 70V.
(EDIT: my memory does not serve me right ! -- the NT1a has an edge terminated K67 type capsule - see here: http://recordinghacks.com/microphones/Rode/NT1-A
If you substitute that for a 'standard' Chinese edge terminated capsule, that polarisation voltage maybe too high?
I have a couple of  edge terminated  capsules -which I bought from Ebay and were specified as having 3 micron membranes - which would tend to collapse  if more than about 50V was applied  as a polarisation voltage.
(They seemed to recover OK once the voltage was removed and then reduced )
Some Chinese edge terminated capsules are specified with 4 - or even 6 - micron membranes, and these don't seem to mind  higher polarisation voltages.
The HF6 capsule fitted to my Rode NT1 (the current issue black version) is itself an edge terminated capsule polarised at c.75V.
(I believe  that the HF6 is a 6 micron capsule).
I have used K47 type capsules - which tend to be less 'bright' than the more common K67 type - with 60V polarisation, but I haven't tried them with anything higher.
I think there maybe be an element of  experimentation required in your project ! :)
RuudNL said:
The choice of a center terminated capsule ('K67') in the NT1, without any frequency compensation it a bit 'strange', to put it mildly...
As I recall - the original NT1 used a centre terminated 'K67 type' capsule, and I believe it was often  considered to be an 'over bright' mic?
The new (black) NT1 uses a specially deveopled HF6 edge terminated capsule, which is less 'bright' .
The NT1a seems to be somewhere between the two (Edge terminated capsule - but with a  K67 style backplate ..
To be really honest: I never heard a Rode microphone that sounded 'good'...
It is not my intention to insult Rode microphone owners, but the microphones I use sound a lot better...
I don't think  the Rode range can compete with some of the best Neumanns and AKGs etc, but then the prices are a LOT less!
I use one of the new NT1  mics - and find it a useful workhorse - as well as a useful tool for comparing to some of my own DIY mics.
I don't think it fares too badly in this comparison clip:  https://www.youtube.com/watch?v=VnrXFC5Pyhs
Not quite in the same league (or price bracket!) as the U47, but holds it own quite well?
If you do download the 32 bit master clips, you can hear where the Neumann has a hi-mid 'silkyness' that the Rode doesn't have.
It's not quite so obvious with the original You Tube  audio....
That is the trouble with many mics though... once you get into the realms of the 'law of diminishing returns',  you need to spend a LOT more money for  sometimes tiny improvements in performance.
The strange thing is that the dead capsule on my NT1a is a K67 type identical to the capsule inside my old white NT1 ... Both are center terminated .
It does look as if it's not quite so clear cut ...
According to these notes from mic mod specialist Michael Joly (on the Recording Hacks page I linked to above) there are three variations of capsule fitted to the early NT1 and NT1A..
"The NT1 and NT1a mics use three different capsule variations based around the K67-type backplates. One of them is center-terminated and is basically a K67 recreation (intentional 8kHz boost). Another … has a HF resonator plate for even more HF [boost]. And the third type of capsule uses the K67 backplate pattern, but the diaphragm is edge-terminated and has a very unusual drilled aluminum plate on the back side instead of the usual back diaphragm".
So a centre terminated 'K67' type capsule seems possible for an NT1a
Hi everybody !
Long time I havn't post
So !
I ended putting my Beesneez CK12 capsule on my old rode NT1.
I have replace & upgrade the two filter caps with some vintage mustard one (c12 / c13).
Regarding the capsule wiring, I have link the two backplates together !
It sound ok, with some cool air, but I still have a LOOOOOOT of sssssssss & fffffffffff
Do you know I could fix it ?
Should I increase the value of those 2 caps ?
Is there anything I could add / change
Thanks in advance !
  • rode-nt1-miroir-revision-1-470769.pdf
And here is the schematic of the schoeps it's based on
Yes, easy to fix. Dont use the CK12 capsule in that circuit and use an RK47 instead.
Problem solved
Sinkia said:
Hey !
It sounds awesome !
I don't have a particularly good opinion of the Maiku CK12 myself. I do think they sound good, but I don't know if they actually sound that much better than other Chinese made edge terminated capsules. It made a noticeable difference in the Behringer B2 Pro I put it into, but that's not really saying much because it was a bright microphone to begin with.
I don't think the Maiku is bad, I just think people exaggerate how good it is. I have heard really good things about their K67 though.
Frankly, I would almost always recommend buying something like the CAD M179 over using a Chinese "CK12" capsule.
Problem solved
I would think the Beesneez CK12 shouldn't be too bad in that circuit. IIRC it's similar construction and sound to things like CT12 and HK12 edge terminated brass CK12 recreations.
The C414 teflon capsule replacements on Fullcompass might be good though.
