RFZ V742dy
adamasnan
Hello everyone, I hope your collective wisdom could help me with a couple of RFZ V742dy isolation/line amps I have:
I got a pair of these cheap, allured by the split transformer balanced outputs, and to see if I could use it for general utilities at least/modification to the input transformer for greater gain at best (?). I understand the +24v referenced to ground and 0v to '-24v', so I have them working, that's all fine (I have V781s also). But I am a bit confused by them both.
Firstly, the main Leitungs Ausgang (line output) works OK, but that's about the extent of it's use.. the problems are as follows:
- Main line out DOES work, but with what sounds like a fixed HPF at around 200hz or thereabouts.. (both units behave same)
- Secondary output DOES NOT work despite being connected on those pins from the internal view, and I have checked the switch, seems to be fine (both units behave similarly)
- Abhörausgang (monitor output) DOES NOT work despite being connected on those pins from the internal view (both units behave similarly)
- I have recapped one of the amplifier PCBs, had replaced C4 (separate to the amp pcb) from a 25v 220uf Frolyt axial to a 63v 220uf Nichicon radial and it exploded after 20 mins! Why could that be?
I would really appreciate some help to get the splits functioning, otherwise I will gut it and use the transformers for something (open to suggestions..)
Some docs attached
