Sredna
Re: KM84 style circuit with electret capsule!?
« Reply #20 on: May 19, 2020, 08:48:20 AM »
You could use a normal resistor for R5 (after you found the right value)
Wrap the transformer (or the whole circuit) in copper foil, and connect foil to ground.
Instead of a pad you could reduce the lower end (C3).
Hmm... in which direction do the electrons actually go?
abbey road d enfer
« Reply #21 on: May 19, 2020, 09:56:26 AM »
A copper foil is no use for magnetic shielding.
abbey road d enfer
« Reply #22 on: May 19, 2020, 10:04:07 AM »
guys, thanks so much for your valuable feedback. Also sorry for the confusion I caused with the 6.8k resistors, in my most recent schematic I changed them to 2.2k.
As I said earlier, it increases the current draw up to 8mA, pretty close to the maximum (10mA), without any improvement.
As some of you pointed out this is more common and also used in the KM84/U87 circuit
What works in these mics does not necessarily work in another circuit. Slavishly copying without understanding why is dumb.
1. part count is still pretty high (space!)
You could get rid of the xfmr, add a transistor for low impedance output, and impedance balance.
2. the little NTE10-3 tranny lacks shielding, so I'm not sure how reasonable it is to go forward with it (the mic itself has a plastic housing)
The mic may or may not be perfectly usable, depending on surrounding interference. Only a test can tell you. You may want to wrap teh xfmr in mu-metal foil...
I would probably need to implement a permanent pad, otherwise I might overload the little transformer. What do you think?
It depends on what you want to do with this mic. You could remove capacitor C4. Putting a pad at the output would be unproductive because the FET stage would clip anyway.
Sredna
« Reply #23 on: May 20, 2020, 04:31:24 AM »
True, but most microphones I know of doesn’t have shielding for the  transformer (KM84 etc). Except for the housing and that’s mainly brass.
abbey road d enfer
« Reply #24 on: May 20, 2020, 04:33:43 AM »
Correct, that's why I said it may work as is.
Khron
« Reply #25 on: May 20, 2020, 12:13:29 PM »
... And on the other hand, what's more prone to picking up EMI anyway? The unshielded transformer, or the 1G impedance on the FET's gate? ;D
Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
abbey road d enfer
« Reply #26 on: May 20, 2020, 12:26:04 PM »
Electrostatic interference is easy to cure, magnetic much less.
xeawr
Re: KM84 style circuit with electret capsule!? New
« Reply #27 on: June 10, 2020, 08:09:21 AM »
- It depends on what you want to do with this mic. You could remove capacitor C4. Putting a pad at the output would be unproductive because the FET stage would clip anyway.
Ok I somehow saw this coming as I was typing the words "also used in the ... circuit"...
I want to emphasize my thankfulness towards all of you who so generously contribute information, time and effort to other people and their interests and challenges. I'm also really thankful for your feedback abbey road d enfer.
As for the:
"Slavishly copying without understanding why is dumb"
I have a background as professionally trained and working tracking and mixing engineer. Most of my fellow audio engineers frankly don't care much about how these things work, they are familiar with their sonic properties and throw those thing in front of (independent and "major") artists and get the expected results. If anything breaks they give it to a professional company to fix it. In the recent years, my personal interest gravitated towards trying to understand the circuits, the components, the properties of the materials used etc. I don't have people with an EE background that I could just call up to help me understand and solve my problems.
Copying a circuit without understanding might seem like a totally dumb thing to some of you, yet, sitting here drooling over these schematics, and wondering how all of this plays together is often my only approach to gain an understanding of what is going. Again, it might seem like a totally worn out approach to learning things, but honestly, it's one of the very few routes I can take that will allow me to make some progress...
So sorry if these inquiries are/were somewhat annoying and thanks again for all your help so far! I really appreciate it, and for my part, I try to remain in the "helper zone" and pass on to other people whatever knowledge I have  :)
« Last Edit: June 10, 2020, 04:52:01 PM by xeawr »
xeawr
« Reply #28 on: June 10, 2020, 08:22:14 AM »
by the way I was able to wire a circuit together and stuff it inside the mic and it actually works - used it on an amp once. Pretty "ok", not overwhelming (most likely the capsule).
But now the mic is so full of components that if I ever have to fix/open it again I think I will just gut it all and try to find a decent dynamic capsule - problem solved  :D
thanks again!!!
« Last Edit: June 10, 2020, 04:53:59 PM by xeawr »
Last post May 17, 2008, 01:03:24 PM
by Gus
Last post September 22, 2010, 09:00:50 PM
by opacheco
Last post December 31, 2018, 03:06:16 AM
by dasnevestheo
Last post May 09, 2019, 04:53:10 AM
by TillM
