-24V and +24V from same power supply?
« on: May 19, 2020, 06:05:40 PM »
I have a power one 24v power supply that i wired two outputs from. one powers a channel strip that runs on +24v.
now i have a compressor that needs -24v, which just means wiring in reverse.
is there any reason i can't run these two things off the same power supply?
buschfsu
Re: -24V and +24V from same power supply?
« Reply #1 on: May 19, 2020, 06:14:17 PM »
answer will depend on ac or dc 24v.  also any requirements around how cheap  or stable the psu is?
PRR said...
OHM'S LAW. Not as an abstract thing: you should be able to glance at a small circuit and "instantly" know I and V, the way a soccer player glances at the ball and knows the angle and kick
pucho812
« Reply #2 on: May 19, 2020, 06:36:25 PM »
is the power supply single output or double output? what does it provide at its output? From your post I suspect a single output power supply  that has AC input and DC output.
if the power supply is a standard linear supply  or even switch mode with single output, to get 24 VDC out of it you are grounding one side of the floating output.
To get bipolar 24VDC you need a second power supply and or a power supply with duel outputs at 24VDC, can build or buy depending on how much work you want to do.  From there it''s a matter of wiring it up.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
mjrippe
« Reply #3 on: May 19, 2020, 06:36:54 PM »
Only if the two units are never connected to or in contact with each other.  It is almost certain that having -24v connected to ground, chassis, etc. on one and +24v similarly connected on the other will cause the PSU to see a dead short.
« Reply #4 on: May 20, 2020, 11:49:19 AM »
okay thanks - i think it's best i not be cheap/lazy and just get another psu!
JohnRoberts
« Reply #5 on: May 20, 2020, 01:40:20 PM »
Unlikely at the same time... each could reference the 24V as positive above system ground, or negative below system system ground. But both at the same time would have ground reference 24V apart.
This might be finesses with cap coupled audio but not simple.
Don't only half-ass tune your drums. Visit https://circularscience.com to hear what properly "cleared" drums sound like.
RuudNL
« Reply #6 on: May 23, 2020, 04:50:53 AM »
Simplest solution.
There is a solution for every problem!
http://www.vansteenisaudio.nl
Last post August 05, 2004, 11:25:14 PM
by Sleeper
Last post October 17, 2005, 06:05:42 AM
by
Last post April 13, 2007, 10:22:59 AM
by okgb
Last post February 28, 2013, 07:50:03 AM
by CJ
