Twist Turner
UTC LS-140 I'm stumped!
« on: May 21, 2020, 10:55:07 AM »
I'm building a transformer filled "color box" I've got 10 in there right now 600:600.........here's one that is just totally stumping me. I picked up a UTC LS140, checked it for continuity and it's good, wired it up according to the info on the UTC terminals chart and i'm getting nothing. So i checked wires to make sure there wasn't a broken wire, wires all good, measuring continuity at the xlr's same as the transformer......but no sound. I thought maybe there was the possibility it was out of phase and cancelling so i swapped leads on one end.........no sound.
Any ideas the transformer at least by continuity appears to be good yet i'm getting no sound......the other 9 in the box all work perfectly.
UTC LS-140
« Reply #1 on: May 21, 2020, 12:13:41 PM »
piqued my interest,
LS-140 labeled as a hybrid repeat coil.
tested a new old stock 140;
strapped terminals 2 to 3,   terminals 6 to 7.
no issues,  flat (-0.3 dB) from 20 Hz to 20 kHz, to and from 600 ohms.
Re: UTC LS-140 I'm stumped!
« Reply #2 on: May 21, 2020, 01:02:40 PM »
Does it look at all like it's been opened?
mjrippe
Re: UTC LS-140
« Reply #3 on: May 21, 2020, 01:31:49 PM »
piqued my interest,
Any chance for DCR or inductance readings?
Twist Turner
« Reply #4 on: May 21, 2020, 01:38:05 PM »
reading with the ohm meter was around 50.5- 51 if i remember correctly that is with 2/3 and and 6/7 jumpered.
Not only didn't it look opened, there it didn't appear to have ever been soldered  before either
moamps
« Reply #5 on: May 21, 2020, 07:30:06 PM »
Maybe one coil is unintentionally internally swapped/out of phase. Apply signal to 1 and 3 and measure signals at all remaining three coils.
rackmonkey
« Reply #6 on: May 24, 2020, 01:53:57 AM »
What ever happened with this? Did you get it figured out?
Whether you think you can or you think you can't, you're probably right.
Twist Turner
« Reply #7 on: May 24, 2020, 12:40:00 PM »
No not working.  What is strange is both 1/2's of the input windings work but when jumpered at pins 2/3 and connecting 1 and 5(there is no 4) when measuring continuity it shows i am getting continuity between the 2 combined but i get no output.......
« Reply #8 on: May 24, 2020, 01:17:59 PM »
the ladies that wound UTC coils sometimes made mistakes.  maybe the polarities are reversed.
Twist Turner
« Reply #9 on: May 24, 2020, 02:27:17 PM »
I tried reversing polarity on the output and got nothing, maybe i should try the input
« Reply #10 on: May 24, 2020, 02:30:31 PM »
It'll be interesting if a coil has flipped polarity.  I've yet to see one that canceled well enough to be effectively silent, there's usually enough of something to sound like a failure.
rackmonkey
« Reply #11 on: May 24, 2020, 05:40:55 PM »
It’s a weird one.  I’m pulling a couple out to fiddle with tonight to see if I can come up with any ideas for comparisons, other than the obvious.
I do recall that the 140 is a weird beast. Very sensitive to source and especially load Z for a 1+1:1+1 transformer. Really big response variations IIRC. But it’s been a while since I messed with one.
I think I remember CJ tearing one down and commenting on how unusual the winding structure was, but I can’t find any pictures or posts on a quick search.
« Reply #12 on: May 24, 2020, 06:06:29 PM »
I saved this in Dec 2009, don't know where the thread is:
this thing turned out to be pretty weird,
ok, so it Is another 31UI, wtf, over? plus, they forgot one of the coils, i am going to call UTC,
this is a Hybrid transformer,
this is something i have not seen since i worked at Aydin Energy building transformers,  folded shields:
so that center winding in this pri-sec-pri rig is buried under two copper shields whose ends are tucked,
this keeps cross talk down to about -92 db , catalog spec,
more weirdness, bi fi windings, this is the splice from the outer pri to the inner pri,>
heavy cardboard in between pri-sec, another weird tweak. usually you want  copper in the window,
how do they wind these things? slowly.. we use to put a piece of mono fish line in between, better C,
 there is a piece of copper in there, inside the yellow mylar, it gets wrapped around the leads,
first layer.  all thw windings are bi-fi,  200t - 400f- 200t, so twice that = 800 turns , pri, 800 sec.
moamps
« Reply #13 on: May 24, 2020, 06:59:01 PM »
....(there is no 4) ....
Is it LS-140 at all if there is no pin 4? On Pin 5 should be wired one secondary coil. Could you post a picture of it?
« Reply #14 on: May 24, 2020, 07:23:52 PM »
Mmmm.   True.
PRR
« Reply #15 on: May 24, 2020, 09:33:51 PM »
https://groupdiy.com/index.php?topic=35773.msg439639#msg439639
All images rotted away.
CJ
« Reply #16 on: May 25, 2020, 03:52:10 AM »
it is supposed to kill all the sound, that is what hybrids do.
only the operator is  allowed to be heard.
"i'd like to make a collect call to US Bail Bonds in Tijuana"
'one moment please..."
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
CJ
« Reply #17 on: May 25, 2020, 04:03:38 AM »
maybe this is not a hybrid, we did hack a hybrid, was that the LS-68?
this one looks normal, i have to clean up the print,
all my transformer prints are in the Magnetics  forum under their brand name.
here is the UTC section.
https://groupdiy.com/index.php?topic=74166.0
« Last Edit: May 28, 2020, 02:25:32 AM by CJ »
CJ
« Reply #18 on: May 25, 2020, 04:17:26 AM »
me wrong. again.  it is the 141 that is the hybrid>
Twist Turner
« Reply #19 on: May 27, 2020, 08:20:12 AM »
I've been busy with some other projects the last week. i'll dig into this transformer later further later in the week.
Last post March 24, 2008, 10:03:54 PM
by clintrubber
Last post June 18, 2008, 02:48:07 PM
by abby normal
Last post October 23, 2008, 05:02:26 PM
by adoucette
UTC LS 140
Started by CJ The Lab
Last post October 15, 2009, 09:30:56 AM
by EmRR
